Not sure if anyone posted this. But has someone consolidated all the custom design for engagement rings?
Would like to see them all!
Super Ideal Cut
0.60 D VS2
Estimate how much arh?
Roughly in the range of $5-6k
Anyone has any idea of the decagon or new stocks of octagon from jp?
wow, so ex meh
Hi guys,
Anyone able to estimate the cost of below trinity ring design? Possible to custom for around 10k? And is cushion cut diamond cheaper than round cut?
Hi guys,
There are different types of cushion cuts. The most sparkly ones are the cushion brellias from Jannpaul. Compared to the normal cushion diamonds, its way better.
wow.. 3 month is very recent indeed. Have you tried on a 1.5ct one?
Yes, they will take the diamond at the original price you bought less 7% GST. Even if you decided to upgrade after a few years, they will still take it at the original price - GST.
And yes, G VS2 is a very good value for money. I can definitely see the color difference between my previous E and my current G, but G is still very white from the top and SIC is super sparkly. I bet no one else would be able to see the difference once it's worn.
In my case, they did not reuse my old setting for my new one because I only gave my old ring and certificate when I collected my new ring. I explicitly requested that as I don't want to have a waiting period where I won't be wearing any e-Ring.
But I guess if you don't mind they can reuse the white gold and the small diamonds pave from your old ring to make a new ring for you and in that case maybe you can negotiate to pay only for the labour cost?
I believe should have quite a few options available for 1.5ct. It's probably harder to find 1.8-1.9ct range but 1.5ct shouldn't be an issue. You can also request for them to check if their cutter have any upcoming diamond currently in production that may fall within your spec. @tostring just got a 1.59ct G VS2 from their recent shipment so I think they should have some other new stocks too.
Who's your Sales person at JP? I found them to be quite responsive and will reply to my email within the same day or H+1 at max
We went by Jannpaul, and took a look at their 1.5-1.9 carat range. It seemed like they didn't have much options for colour G of that size. We were keen on one of the ones shown @ 1.8+ but the table size was a little on the smaller size. We were advised to wait for their next shipment, which would come in at (??). I wonder how long do I have to wait! Given that SIC for 1.5 & above are rather hard to come by
How small is small?
Pple would request for colors n maybe clarity but table size is quite specific. Frankly, I doubt many pple can see the difference of a 1% table size (eg. 55 vs 56%)
Pple often want more fire without realising a smaller table enhances fire while a bigger table more white brilliance. Of cos this is just one factor but u will find that a smaller table is sometimes more sought after
If time is on your side, no harm waiting but if not then perhaps consider your options
It was a table of 56% versus my older one which is 61%. The 61% had more white brillance, you are right about that.
@hope84 @miltah
I made a terrible mistake. It was a table size of 58% vs the new 56% one. We are going from a 1.3+ to a 1.8+. We tried it on her hand, and thought that the size did not look significantly bigger for the upgrade price that we were paying. We played with a 1.9 carat (7.99m across) and felt that it looked so much closer than what we wanted. Suspected that the 1.8+ diamond was a little heavier at the bottom. Not too sure, any experts here care to advice?
gia.edu/report-check?reportno=2347553611&s=1580800182513
That’s a classic SIC dimension.
It’s on the deeper side of things but still within limits
A smaller table will make the stone look smaller for more fire
A larger table will make it look bigger with more brilliance
@hope84 @miltah
How would you know if its a "deep" cut or not? Which value do you refer to? Is it the depth?
