andytantravels
- Jun 8, 2019
Hi! May I know what were you quoted on the 0.91 diamond?
ds
It's a once in a lifetime purchase bro. I'd wait to get a custom cut one in your specs.
It'll take 4-6 weeks for them to handcraft your ring. You'll need to plus another couple of weeks if you plan to customize your design. Their 3D work will take 1-2 weeks and another week to do up a wax prototype. Since you're custom cutting cutting your diamond, you might as well custom design your ring also. They don't charge extra for custom works.
To save time, you can start your custom design while waiting for them to cut your diamond. Then once your diamond is ready, you'll have your design ready also then just need to wait the 4-6 weeks for them to craft.
Have fun with your ring 3D. My fren recently did his 3D with JP, and it looks different from the old ones they used to do. It looks very cool and realistic now.
Thanks. I've placed my order to custom cut with them liao. Excited to see what the cutter comes up with.
The Oval hears and arrows they quote me is 9.4k. Its a 0.91 E VVS2
