Proposal Ring - Part 4
bentyh
Swee! The scopes looks perfect. Their cut precision is the next level. Was yours a custom order?
That's great to hear thanks! Yes, mine was a custom order. Had an appointment with them on 9 Apr and then on 24 May the diamond was ready. They have begun the crafting and the final ring will be ready before end June! Really happy how fast the entire process is. So excited to collect it!
marsbarsz
anyone knows any good boutique that carries both cultured (lab grown) diamonds and gemstones together?
looking to explore accessorising the diamond with gemstones by the side
That's fast! Yours only took 1 month+. Out of curiosity, what design did you make with them?
coldwinter00
Went down to JannPaul quoted below spec
Cushion 8 Hearts and Arrows
0.81-0.85
F-G
VVS2-VS2
Around 8200-9000
was this consider reasonable price?
Cold_Fire_18
Hi guys, need your opinions on this diamond. A little hesitant as it is a flat 0.60 carat.
AGS 104113632030
freewilly5000
Does this has potential? GIA 2213607444
Hmm.. proportions is ok. Not to Super Ideal standards but neither it is on the very bad side. The table is 59% which is on the larger than ideal size. A larger table can give the diamond a larger / flatter look, but its at the point of sacrificing the fire / scintillation (sparkle) for it.
This is just based preliminary on the proportions on the cert. It would be more accurate if you have the ASET scope to analyze the light performance. A diamond can have perfect proportions but poor light performance. So the scopes would be more useful to analyzing this.
Pryson
Thanks will check that out. Look into this because of the attractive mid 4k price quoted. Will check more details.thanks!
undftd7
Would like to seek opinion from fellow members on this specific diamond as I was offer it by JP after about 2 months of wait.
AGS 104113668013
Decagon 10 hearts & arrows
Shape and Style: Decagon Brilliant
Measurements: 5.41 x 5.15 x 3.39 mm
Cut grade: AGS Ideal 0
Light performance: AGS Ideal 0
Polish: AGS Ideal 0
Symmetry: AGS Ideal 0
Additional clouds and surface graining not shown
Carat Weight 0.593 cts
Fluorescence: Negligible
Color Grade: (E) AGS 0.5
Clarity Grade: (VS1) AGS 3
ke3bbs
Hi Guys, will need your comments on the below decagon diamond.
AGS 104112780002
Much appreciated!
koifishclown
AGS 104113668013
Polish: AGS Ideal 0
AGS 104112780002
Much appreciated!
Wah.. the decagons are getting very popular. So many ppl buying them now and I can understand why. lol. The AGS cert itself is already the best available cert (better than GIA IMO), and much stricter than those shady IGI, EGL, etc. ones. Plus the decagon are JP's white series (I believe the decagon is the highest light performing one out of all the shapes). You're in safe hands with JP.. The diamond is as perfect as it can be.
Wham
Hi Guys, please comment on the below 0.478 Decagon diamond. Was offered this when i visited the store.
Not a custom cut, balance stock.
Appreciate your feedbacks.
flamistro
Hello! Can help to comment on the following diamond please?
GIA 6375176651
Thank you in advance!
chesterchew
Scopes looks perfect to me. The ASET shows strong light return. What's the color and clarity grade?
chesterchew
GIA 6375176651
I'm assuming you didn't see this diamond under the ASET scope? Because based on the proportions I see on the GIA, the diamond won't be a good light performer. It's on the steep deep or top heavy side, which would usually show the ROD (ring of death) or light leakages at the table. The crown angle is way too steep at 36 and the depth is over 62%. So the diamond will also look smaller for its carat weight. Though a 0.67ct is a nice size just under the 0.70ct mark, it won't truly look like a 0.67ct size.
Also the star facet is 45%. Ideally it should be at least 50%. This in a way controls the size of your sparkles. So smaller star facets = smaller fire. I suggest trying to see the diamond under the ASET and it should reveal all the visual issues with it.
