koifishclown
- Mar 11, 2019
Can someone share what aspects of the diamond determines the brilliance and scintillation performance of the stone?
I was physically (naked eye) comparing between a JP white series oval and a cheaper one, cannot really tell the difference under the same lighting conditions (natural light and spot light)....
Under a scope i can see the cheaper one doesn't have the nice aligned arrows, but doesn't seem like it affected the light performance...
JP:
non-JP:
Image quality is pretty bad as i am using an old xiaomi phone...
The pics you took are in the hearts & arrows scope. That's to see the symmetry (not light performance). For light performance, you'll need the ASET scope. And I think the photos you took, the diamond is abit tilted so can't really see it accurately.
JP's white series oval itself is the best light performing diamond in the oval shapes. You can see the evolution of the oval diamonds here;
Then JP's oval is meant to outperform the SIC rounds as well.
This is an old pic when I was down their store before I bought my oval with them (under direct light). It was sparkling like mad. And I also rem their ovals lower color looking brighter than the SIC round even though it was a higher color (under their white light box thing at the shop corner).
Btw, are those 2 diamonds on the side of your oval pear shape? You got a photo of your ring itself? Curious about your ring design
