Hi all,
Can help me see if this diamond is good? I not sure what to look out for.
shape and style: decagon brilliant
Measurements: 6.12 x 5.83 x 3.79 mm
Cut grade : AGS Ideal 0
Light performance: AGS Ideal 0
Polish: AGS Ideal 0
Symmetry: AGS Ideal 0
Color: E
Clarity: VVS1
Carat weight: 0.852
PROPORTIONS
Depth: 65%
Table: 54.2%
Crown Angle: 35.1 degrees
Crown Height: 16.6%
Pavilion Angle: 40.6 degree
Pavilion Depth: 44.8%
Girdle: Medium to VeryThick
Hi guys.
Is this diamond good? Seek some experts here to help.
The Decagon cut is JP's white series range which is already filtered to be the best cuts already. It's gonna be super sparkly. I believe it's even stricter than their SICs. You can double check with the scope images. So far all the past white series scope images that the others posted are all very good.
My only comment is the clarity you guys chose is very high. VVS1 and IF. I feel dont really need such a high clarity since they already dont take in black inclusions or the other problematic ones. So technically, their VS1-VS2 is good enough liao.
