SecretAgent
- Mar 15, 2002
Fujian brand is good!
how long u used the last one, and how much is the whirlpool? got model to share?Ugh you also Samsung washer up the lorry? Mine died last month I damn dulan, never getting on from them again. Bought a new one from Whirlpool, cheap and good.
how does that look like?Please check whether its the sheety water filter saving water crap little piece of metal that's blocking the water flow.
Its located in the outlet of water to the WM.
Remove this piece of rubbish. It may be the gunk that has formed a biofilm so that water can no longer go through to the wm.
Treat me kopi if this solves your problem.
include transport fee?My washing machine just had a choke at the water inlet. The repair cost is only $60. You can PM me for a simpler and cheaper solution for the repairman contact.
what's the life span like before its demise?Ugh you also Samsung washer up the lorry? Mine died last month I damn dulan, never getting on from them again. Bought a new one from Whirlpool, cheap and good.
3 years. Quoted 600+ repair.what's the life span like before its demise?![]()
frequently used? as in 2 3 x per week?3 years. Quoted 600+ repair.
Samsung washer got problem and you still want to buy another Samsun washer? You ok or not?my samsung washer gone case already. water cannot pump out.
Intending to get a replacement.
Is this a good choice?
https://www.samsung.com/sg/washers-and-dryers/washing-machines/top-load-7-5kg-silver-wa75h4400ss-sp/
Yes . That shitty thing spoiled my Samsung washing machine according to the repair man.. cause the water too small then the water sensor needs to over work causing it to broke down easily.. once the sensor broke down the water won't come out anymore..Please check whether its the sheety water filter saving water crap little piece of metal that's blocking the water flow.
Yah 2-3 times per week. The repair price was so off putting as I can top up $100 more for a new one, which is what I did.frequently used? as in 2 3 x per week?
but $600 for repairs, forget it
they can give u at least a 3 mth max warranty
after that, good luck![]()
My friend also recommend Bosch not because it's reliable. He bought it because he say got many independent repairman can service it if got problem, they can also buy original parts to repair.Samsung washer not so reliable liao. Moi change to Bosch front load can save water too
never listen to salespeoplewhen i buy washing machine hor, i were a few different store
all tell me dun buy samsung washing machine
they only exterior look very nice
i not a pro in this but i been using LG can LG didn't give me any issue for years liao
