Recommend a washing machine, please?
luei74
My friend also recommend Bosch not because it's reliable. He bought it because he say got many independent repairman can service it if got problem, they can also buy original parts to repair.
WAT28482SG​
we gotten the above model with Goh Ah Bee on Aug 2021, so far so good up to today. Thanks for the repairing tips..
Positiveman
never listen to salespeople
they will always say the low comm one lousy and the high comm one is the best
but u see the comment, a few people say samsung like not very good leh
i last time samsung supporter but now i turn to LG liao
thyler_koh
when i buy washing machine hor, i were a few different store
all tell me dun buy samsung washing machine
they only exterior look very nice
i not a pro in this but i been using LG can LG didn't give me any issue for years liao
True story
covidneg
my samsung washer gone case already. water cannot pump out.
Intending to get a replacement.
Is this a good choice?
https://www.samsung.com/sg/washers-and-dryers/washing-machines/top-load-7-5kg-silver-wa75h4400ss-sp/
Does your pump motor has working sound when it tries to pump out water? If yes, highly there is a clog at the below drainage area, removing the clog will fix the problem.
This kind of clog is not at the normal clog that can be removed from the usual bottom trap door, it is higher up, just before the pump.
You need to dismantle the bottom and trace it slowly by reversing up.
virtualape
Samsung washing machines have mold issues, never have such issues with other brands.
It's ventilation causing mold. Mine is front load, parents place top load. No proper ventilation, any brand will also suffer from mold.
Wash finish, open the door and detergent tray to air. Kitchen windows are open. Every month wash it with a cap of bleach. Never encounter mold before.
megaweb
My LG washing machine spoilt recently. It could not spin dry. It was 7 years old. I called up their hotline, they came down to replace an adapter part and charged me $85 ( including transport ).
Vulpix
Moderator
Moderator
Same, I leave door open, never had mold issues before. One time my son go close the door after wash, 2 days later open got weird smell. Since then will always check if its open.
virtualape
I'm suspecting wash finish never collect immediately to hang. A few hours later, the chao sng smells kick in. Plus never open to dry..over time I think mushrooms can start growing underneath the washer...
kenpachi82
how does that look like?
images
