Recommend CPU Cooler for 5600X
86technie
Or maybe i should just str8 away spend more on a Arctic Freezer?
Read that Arctic Freezer II 280 is recommended?
P.S. Edited Thread Subject and 1st post.
Edit 2: Seems that my Tecware Forge M can only use Arctic Freezer 240 since it can only install 2x120mm fans at the top. Am i correct?
If you can stretch your budget, suggest:
- Change that crappy Tecware casing reliability as well as airflow is bad down the road.
Example Cooler Master MB520 ARGB - $119
The stock fans of this casing are decent so need not upgrade.
Far better quality and realibity than Tecware.
Casing there are others but this would be the cheaper option.
2) Cooler Master Hyper 212X Black Edition
I don't see the point of getting a AIO cooler for a AMD 5600X, air cooler will do fine.
Not to mention AIO cooler have lifespan, if the cooler gets noisy as well as temp
shoots up than you have to replace the entire AIO cooler.
Air cooler wise only the fan can wear out but very unlikely.
I still recommend you to strike a balance to get a good casing that have fans with good airflow
to go along with a cooler.
Than buying a strong CPU cooler but the casing is crappy quality.
Anyway the decision is yours.
nagase_4
Hello again! and thanks for above.
How what if i change the existing case fans of my tecware. Will it be better instead of changing a new casing?
Reason is because bring home a few fans much easier to answer to wife than a big casing. 😅
86technie
Also can but Tecware products are not known for reliability.
Casing you can buy from Lazada SG stores.
Phen8210
Just thinking whether should I or not lo. Can afford la but need to or not is another thing.
So now just wanna ask u all more and weight all the pros and cons then decide by this couple of days.
Cos my new CPU 5600x should be arriving around 9th May thereabouts.
Tecware products are known to be not durable and will spoil, so be it.
However, a single case fan spoil doesn't break your entire system, and you can replace them in the future. Plus, if you happen to be lucky, they might last for you. Note that upgrading fans don't have the same impact as adding a fan, and you might not notice significant improvements. Not to mention, the 5600x doesn't need much cooling.
As for the CPU cooler, the SE-226-XT cooling is strong and can also cool a 5800x. As for the 212, it's an old-school recommendation, and other coolers have long surpassed it at its price segment. I need to put bluntly that a 240 AIO is not superior to a good HSF that is half of its price, which I did not say earlier.
It would help if you focused on your priorities
1. CPU Cooler - You need one.
2. Case Fan - It's seldom worth upgrading fans. You can do that when there is a problem with the fans.
3. Case - The case isn't going to collapse. Airflow-wise, your Forge M has meshed front and is not as bad as the Nexus M, which is completely suffocated.
You need to understand that cases with meshed front panels are typically unrestrictive and sit in the higher segment of the charts in terms of airflow. Even a terrible one will never drop to the 'bad airflow' category. That spot is reserved for cases like the Nexus M.
In the future, let's say your case fans and io ports 1 by 1 start to spoil, then it makes more sense to change it. Otherwise, it may look like you have too much free time on your hands :ROFLMAO:.
nagase_4
@Phen8210 ikr, looking like I have too much time on my hands is no1 killer in my house, especially when i spent the time messing with my rig. Wife confirm death stare till i burn! :ROFLMAO:
@techidiot despite it being very tempting to change to a new casing, i think i will hold it off for now. If now from a budget hsf go to a AIO goto change case...lol. Will just upgrade my current case's fans one by one to see how it goes. Thanks for your kind advices since the beginning of this thread though. Totally appreciate it! (y)
Anyway, I think I've kinda decided. Going against most advices, I most prob should be getting Arctic Liquid Freezer 240 (Must get at least Rev4 right?) and also shunbian just get a CM Sickleflow 120mm. Should be getting them from Bizgram since I just whatsapp-ed them and they have available stocks for both items.
Getting a AIO instead of a HSF, for me, is mostly because of Aesthetic reasons. And also since I had never owned a AIO before, just wanna try one now.
Again, thanks to ALL for your advices and contributions.
Still continue to welcome more posts and opinions in this thread since this topic should be quite useful for most people like me, who had always used stock cpu cooler and wanna try something new.
86technie
Cuz TBH if you have money to spend I rather you get a much reliable casing than Tecware.
Like @Phen8210 also shared, Tecware fans are not durable can fail down the road.
The power button as well as USB ports do spoil also and these are not replaceable.
I have recycle quite a few Tecware cases due to either faulty USB ports or power button
which either jam or does not turn on the PC. Since you already set your sights on AIO
than go ahead but for beginner you have to learn how to install it.
CM Sickleflow fans are the budget friendly high airflow fans cuz the next level will be Noctua
but they are very expensive as well as no RGB.
ZhuTou!
AIO not that bad la but ya it will degrade over time
My old rig never oc and seldom game, used to oc but reset to default after few yrs
My AIO last for 10yrs haven spoil
The temp go up few deg, i think from 35 to 40
The good thing abt AIO is ur rig will look alot more spacious
Looks neater and cleaner also coz lesser things to trap the dust
If use air cooler after few yrs, u open up casing ur cooler will look like pork floss
But if looking at cost, of coz air cooler will be cheaper
Koenig168
If you are looking for cooling stuff, you can check out Aigo on Lazada. Lots of good deals as there is a promotion going on. Quality-wise, I won't expect much at these prices. :)
ragnarok95
Senior Moderator
Senior Moderator
His Forge M casing has better airflow than the coolermaster MB520.
tremor
Ryzen 5600 use any cooler also can. My other rig use ID cooling, pink color one cos my wife using it.
nagase_4
Today wake up, suddenly felt and thought of the following:
Get SE-226-XT better
- HSF durability longer than AIO
- Less headaches and worries. HSF spoil, change fan or change whole HSF. AIO spoil, may be pump spoilt maybe other things spoil. Also got very small chance of leak due to old age.
- $50 HSF is equivalent or better than a $150 AIO
I'm so fickle minded.............
nagase_4
Hi all, need help. How do i connect the sickleflow 120mm ARGB to my hub?
The sickleflow comes like tat. So the red circled wire is the "power cable" which should be connected to my MB while the blue circled cables are the ARGB cables right?
So now, looking at my RGB hub, it seems that the female/male connections does not match and there's no way i can connect the ARGB cables to the RGB hub.
How ah? I lost liao...
Rapt0r
Tecware's default hub is 6 pin, cannot connect 3rd party ARGB devices. Check your HSF see if it comes with a separate ARGB controller, connect your CM fan's ARGB to it.
nagase_4
I think the HSF does not comes with aeparate ARGB controller.
In that case, based on my MB layout, which cable should go into which connector?
Anyone can advise please.
Thank you.
nagase_4
20, and if it is being used you need a splitter
dont plug to 24, will fry
my preference is to cut away the RGB wires for settling such problem
I actually thought you would get the black 226 cos the ARGB version more expensive :ROFLMAO:
U mean the blue circled cable plug into 20 right.
Then what about the red circled cable?
yea i bought the argb cos i hiao lo...lol!
