Recommend water heater
Opps-gal
because storage water heater I have changed it twice and the same problem occurs.
and I can only install one Ariston model.
Read HWZ Forum Rules!
I am using ariston storage heater. The previous also ariston storage heater, but leaked water after 5 years.
Still prefer storage heater as no electrocuted news. Before both storage heaters, I am using instant.
feeltherain
I am really about the electrocuted news too so I am in a dilemma. storage type water heater I just cannot tahan anymore
xcodes
how much does the storage tank type of water heater cost?
1982-1994
Currently using Ariston water heater (those big water storage type one )..for both bathrooms heating.
Thinking of switching to wall mounted smaller water heaters for both bathrooms.
heard 707 brand is good but I wish to know if there are other brands out there which is quite good also ...
Using A.O smith storage heater Gen 6 and it heats up the water within 2mins
Can adjust the temp too
jtsh55
jtsh55
thanks for sharing bro ... is it good so far?
Very good, as the max temperature can be set at 75 degree Celsius if you need a very hot water shower and the water pressure is very strong even if you are using rain shower.
xcodes
thank you bro once again ... :)
Alphas
Not true that instant water heaters have weak water pressure. Many of the instant water heater now comes with built in water pump, it can increase the water pressure more than those from storage water heater.
antsig30
My 707 Kensington 25L started to leak at the cold water inlet last week. Already used for 7 years. The leakage is very small with droplets accumulating. I thought of calling 707 customer service to quote for a repair. I suspect maybe just need to change gasket. Have been calling for past few days but no one pick up. Very bad customer service. :(
alex22
Panasonic one. Local set 30% more ex than jb set. Stock comes from Malaysia
testerjp
I deal with boilers.
Storage heaters have more points of failure than instant heaters.
I recommend Panasonic, it has inbuilt circuit breaker.
alifffresto
Bought a mistral mwh-38q with elcb from shopee my for less than $50 then self installation
testerjp
Almost all the cases or fatality from instant heaters came from self installation or from inexperienced and not certified technicians. :o
