Recommendation for portable Air Cooler ..
Lchlch
I was browsing shoppee for portable aircon.
Some cost less than $50.
deathan9el
Honorary Mentor
my sis has one in one of her rooms but it were made cooler b'cuz the room has a ceiling fan as well
if both turned on, it's as good as an AC
on its own ..
but a portable AC may not be as strong as how u feel/try at the display store (it's helped by the store's very own AC surroundings)
jeffprobst
For the umpteenth times, get a proper system 4 split air con. All these portable or casement Aircons are just bad.
Not everyone can afford to install multiple aircon units. Sometimes, the other rooms already have aircon, and it is just one specific room that does not. Instead of replacing the entire system just to add cooling to that one room, people might opt for a portable unit.
In my case, the other rooms have aircon, but mine does not as Im staying in a utility room, and there’s not even space for a portable unit.
Lchlch
on its own ..
Yes it is ok cos also switch on the fan too.
ramlee
High Honorary Member
How come you so poor thing? :(
deathan9el
Honorary Mentor
not sure which brand my sis currently using
but it's the bulky one w/ wheels
didn't use any ventilator ugly pipe either
just that & the ceiling fan
really cooling 🥶
