Recommended Motherboard and Intel Processor
MoneyFace =p
I thought of the G series too but then just for a little bit more can get a better integrated graphics why not.
~$100 for better IGP? Not a good deal.
Rather he get G3258 + any sub-$100 discrete graphics. Far cheaper. Unless he needs HT badly.
carlover76
asus has a nice bios suite to work with but cost more. Asrock H81 is the cheapest.
Thanks for the info but I have never tried Asrock and I have been using Gigabyte all these years with no issues so thinking to try ASUS for a better Motherboard this time. =:p
carlover76
shadow84
carlover76
IGP is now on CPU rather than motherboard. So whichever motherboard you choose graphics will be the same.
Thanks. I just check my old pc which is on gigabyte GA-EP43T-UD3L motherboard and with 2 pieces of 2GB DDR3 Ram.
ykgoh
G3258 has Intel HD graphics built-in. And TS only surf net and watch movies. Why recommend a discrete graphics card? :s11:
lionheart80
sry TS hijack ur thread a bit since u also on the topic of choosing m/b
am getting a i5 4690k with either gigabyte ga z97 d3h or asrock z97 pro so not sure which m/b is better
fellow bros any advise???
carlover76
If I get the Asus Motherboard, it also has built in graphic card and can use that, right?
MoneyFace =p
Just to illustrate the comparison between a choice of Core i3 vs Pentium G + discrete graphics.
carlover76
Motherboard does not have any integrated graphics as mentioned earlier......
Oh thanks, I saw something like this :
"Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 1920 x 1200 @ 60 Hz
Maximum shared memory of 1024 MB
Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Dual independent displays support with HDMI/DVI and D-Sub"
I thought it has integrated graphic card?
carlover76
its in the chip
not motherboard
So it means it support those features but it has no integrated graphic card in the motherboard.
Guess only certain brand like Gigabyte or MSI has built-in graphic card.
Jian19
nowadays motherboard no igpu
its all in the chip/cpu
why u dun understand simple english ? :s22:
