Recommended Motherboard and Intel Processor
MoneyFace =p
Hi,
My old PC Intel Core 2 going to retire soon so thinking of upgrading the Motherboard and Processor.
I like to check with you whether any recommended Processor (i5 or i7) and Motherboard as I am using Gigabyte motherboard. I don't really play games on PC but more for web surfing and watch movie with 1GB Fibre plan.
Appreciate your advice, thanks.
Thanks. I just check my old pc which is on gigabyte GA-EP43T-UD3L motherboard and with 2 pieces of 2GB DDR3 Ram.
Guys, sorry for the confusion.
Any recommendation for the RAM and Windows OS?
Yes, agree. Already 6 years le so time to change a new one and already gotten the 4TB HDD and can use back my Plextor SSD on the new setup.
Probably around $500+ including RAM.
I should be using back the below items :
1) Plextor SSD 128MB
2) Maxtor 4TB HDD
3) 1 x DVD-Writer
4) Cooler Master Full Tower Casing with Power Supply (Have to check whether power is sufficient)
I have a old NVIDIA Graphic Card but not sure want to use back.
I see. I guess I can get those mouse meant for Win 8.1 instead, right?
I should be interested in the Metal Gear Solid 5 which I love this series from the start. =:p
With the integrated GPU, can it support such game?
To sum up what you need and what you'll really do with this PC:
1. Initially you not intending to play game, now you want to play Metal Gear Solid V
2. You already have 2X 2GB DDR3 RAM sticks, 128GB SSD, 4TB HDD, ODD, PSU and chassis you want to reuse
3. You also have $500+ to spend inclusive of OS.
Minimum Specifications for Metal Gear Solid V
OS: Windows Vista 64-Bit or later
Processor: Core i5 Sandy Bridge 4 Core (4 Thread) 2.7GHz or above
Memory: 4GB RAM or above
Graphics: GeForce GTX 650 or above
DirectX: Version 11 or above
So here's my suggestion:
CPU+MB: Intel Core i5-4460 + ASRock H81M-HDS R2.0 @ $294
GPU: Sapphire HD 7870 2GB Dual-X OC @ $140 (Convergent Systems Service Centre)
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $115
Total: $549
Buy others from Tradepac, #05-18.
Please reuse your 2GB X2 RAMs, they should have lifetime warranty and get them replaced should they be faulty (if error found with memtest86+).
Please also ensure that your ODD uses SATA interface and not PATA/ATA/IDE.
carlover76
Total: $549
Thanks for the summary, I will check the RAM with the Memtest86+ before bring down the whole set down to PC Themes.
carlover76
Total: $549
I finally got my setup yesterday at PCThemes with the following :
1) Intel i5-4460
2) ASUS H97 Plus Motherboard
3) 2 x 4GB Kingston RAM
4) Cooler Master CPU Cooler Unit
I never change the PSU as Derrick told me to reuse back the PSU first and when there is a need to add in a good GPU then change the PSU at the same time.
However, I try to put in 2xHDD after setting up the Windows 7 on my SSD, I press the power button but it cannot boot up, not sure it is the symptom of overload for the power supply.
Any advice?
mib500
1) Intel i5-4460
Any advice?
you never test at PC themes?
shadow84
1) Intel i5-4460
Any advice?
While installing OS to ssd, i can presume both hdd are disconnected? Do check in Bios to see if they are detected and enable. Also, do try out with 1 hdd to see if either is faulty.
carlover76
No, I never bring down my SSD as I will be using back my previous Win 7. I thought I need to purchase another copy of Windows but the activation is so simple to install onto another PC with the same license key.
Thanks, I will try to install one of the HDD first and add in one by one.
Yes, when installing the OS, both HDD are disconnected.
mib500
then you should try what shadow said...
shadow84
Sure, I will follow what Shadow mentioned and plug in one HDD at a time, if the system not able to power up then no choice but to replace a new PSU.
That is not psu issue but hdd issue. If ur system can boot with ssd alone, psu is fine.
