Red Wing shoe Thread
el_guapa
Oooh, so the soles are still good year welted except for the white portion?
YEP! Do a quick search on Google, Red Wing shows a cross section of their boot construction.
I'ts what makes their boots even better, in my opinion... My first pair lasted me since the early 90s, when they had their store at Far East Plaza. I had those resoled 3 times in the 20 odd years I had them. They unfortunately got chewed to sh*t by a dog.
yanbros
Hi guys, may i know how long u all use ur red wing shoes before they start to give way and did a resole? I used mine for 4 years and the sole starts to open up...
I wear my RWs almost daily except on the weekends and the back of the sole last less than a year. I asked the cobbler at Shukey in Tampines 1 why so fast wear out, he say you don't see white tires on the road do you? I just LOL....
-nzy90
But 1 year is really fast. I wear my rw at least 4-5 days a week and those days I wear them I walk at least 10-15km. On my 3rd year already and no resole yet.
Sent from Samsung SM-N910G using GAGT
imperio
Hey guys, received my 875 today and realised there is this cut on the corked mid sole which exposes a big part of the stitching.
is this normal or a defect? :(
kazuki666
The stitch seems to be sitting nicely in the slit. I worry that the thread may come loose. Where you bought it from?
imperio
I bought it from an online shop, funny thing is on the other boot there is a cut too on the exact same spot except it wasnt as deep as the one shown.
kazuki666
I just realised my 8165 and 875 have this slit too... :s22:
But confirm no problem, they have been with me since 2010 and no signs of loosening. Just that I may need to resole soon...
I die die want to tahan until can find someone to do heel resole, rather than the original crepe sole
imperio
Your reply gave me some assurance ;) since 2010!
Btw I bought their leather protector spray, is it a good idea to spray them on prior to first wear?
sinistral
My 3141 has them as well. I don't think it's a defect.
likehotbutter
That is normal. It is the welt joint
The welt is a strip of leather, not a solid ring. There will always be a spot where the two opposite ends meet.
Higher end footwear the ends will be nicely spliced into each other. As for this price point and purpose as a work boot cant expect much
patryn33
u just want the heel done? not the full crepe sole?
red-wing-shoes-875-6-classic-moc-toe-oro-legacy-red-wing-shoes-875-oro-legacy-classic-moc.jpg
likehotbutter
Think he wants a heeled sole like a normal boot. Ie Iron Ranger etc.
Anyway this will require a recraft unless he wants a cheaper glued together job. Remove the thin normal 875 mid sole, welt on a thicker (or maybe same midsole) and leather/commando sole. Then finally nail in the heel block.
There is no proper goodyear welt machine on local shores anyway. Need to send these overseas. Its for this very reason that local authorised resole jobs are only for glued crepe soles and not for welted soles like an IR.
EEA or M&S may possibly take on the job but it wont come cheap. 180-200
patryn33
That's a full resole removing the entire sole not just heel
Edetal Already cost $180.
Converting 875 to dress boot hybrid
Anyway 875 is a normal boot just work boot. Iron ranger is normal boot just dressier
U make 875 kinda boot sound like abnormal boot lol
