Red Wing shoe Thread
alanjw55
suntec and bugis
us website they use "name" instead of "number" to name there model, actually the same except rw japan
oh okay thanks for telling me...will do a bit of research..btw im going to KL the following week, would it be cheaper up north in KL??
mikeeeey
actually what do you call the difference between these 2 soles? besides the material. im referring to the style..
and
anyone knows? thanks in advance.
mikeeeey
anyone using shoe tree for their boots? or they are not meant to be used together in the first place?
cos i find shoe trees mostly for dress shoes.. but it helps removing the moisture inside, doesnt it?
mikeeeey
Iron Ranger and Round Toe
thanks, but im referring to the soles.
the iron ranger one is not totally flat, like dress shoes soles but more rugged. the round toe's one is like sneakers kind, flat to the ground
easy_hk
heels and full sole ?
victortys
should the best fitting be very snug like your toes touching the tip of the shoes or some room space for the feet to move slightly?
kohkj88
Hi, may I know what lace would you recommend to go with the 3140 chukka? I find that the stock shoelace won't last long....
mikeeeey
im interested in the chukka.. but i want to own a full boot (dont know if there is a word for it, but those boots that are like Iron Ranger etc)
but yet again im worried about the difficulty to take out the boots like IR when I have to enter places that require me to take out the boots
esteliv
sorry guys for the noob questions.
i am interested in the Classic RW Black Moc Toe boots.
however, after researching for abit.
i realise rw at suntec retails them for 400+ ? and theres sellers in HWZ doing MO for as less as $280 to 300++
is there a difference in quality ? i heard they're made in different countries...
SinRed
They're prob selling factory seconds.
I bought 1 off eBay too. Just collected from SingPost today. USD$79.90 factory seconds 875 for my old man. :D
Looking good.
No defects. Notice the punched holes on the tongue? I guess its by Red Wing to distinguish it being factory seconds. Nicely printed on the shoe box are the words "FACTORY SECONDS" too.
Notice the scratch at the heel area? Nothing serious thou. Nothing that you won't get on your boots after couple of wears.
Red marks on the sole.
For this price, I'll say it's very worth it. Cos all are cosmetic 'defects' if you wanna call them that. I dun mind, since Red Wings are meant to be grind. ;)
Glad that my dad likes it. First time he nvr kp me when I buy ex stuff. He saw my pair of Red Wings
<--Mine
and asked me, "Red Wings ah? How much?" When I told him $200+ he kept quiet. Being the frugal man that he is, I think that he must hav wanted it when he was younger. Saw the boots on eBay and decided to get for him. So now, we have a 62 yr old man rocking his Red Wings! Woot!
n0va_jason
Thumbs up for filial son and cool dad rocking Red Wings :D
easy_hk
Looking good.
<--Mine
can share which seller u bought from on ebay ?
thx
SinRed
second this...
Thanks!!
thx
No problem. But at this pricing, only left the odd sizes which I dun think you can wear. Size 13, size 4....
http://shop.ebay.com/papashoelo/m.h..._trksid=p3911.c0.m14.l1513&_vc=1&gbr=1&_pgn=7
The link above is all the items that the seller sells. It's the last page which I sorted by lowest price to highest. So you might want to check out the middle pages where there are retail quality 875s going for USD$149.99.
goat1991
Can advise me which size should i choose for red wings?
Foot size: 28cm by 11cm
wears US11 normally and UK10 for clarks DB...
TIA :D
