ZhuTou!
- Oct 6, 2008
Cam is n10proredmi 10 pro camera better or x3?
I have both.Would the Redmi Note 10 Pro be a better buy compared to Poco X3 Pro?
Do you game on your phone?
Don't really play much games, just a bit of light gaming. For photos, as long as the camera is decent will do.
Is there much of a difference in screen quality since Note 10 Pro is using amoled?I have both.
1) Colour - Putting it side by side, Note 10 Pro is slightly brighter (based on same brightness setting). I won't mind the colour of X3 Pro as don't really feel if anything pleasant is missing.
2) Cpu - Obviously X3 Pro is winner. If you are not playing games, probably you won't miss anything too using Note 10 Pro.
3) Camera - Note 10 Pro should be clear winner based on so many reviews on internet. I have not actually compared them.
4) Sound - Don't know yet as my Note 10 Pro is still new. Based on my experience, sound quality needs some 2-5 weeks to reach the best sound. At the moment, I feel X3 Pro sound is slightly better.
5) Look - Note 10 Pro is better to me as it is slimmer.
I am aware that it is Amoled vs Ips. No big difference really and may be slightly brighter and sharper, only if you compare them side by side. See my earlier comment on colour for screen quality. For Cpu, it is Snapdragon 860 vs Snapdragon 732G. If you play games, may be you will see a big difference but for my type of usage (mostly calls, sms, video, songs, web surfing, whatsapp), both are fast and smooth enough and I don't seem to miss anything. Battery life, I think both are good.Is there much of a difference in screen quality since Note 10 Pro is using amoled?
If I'm not wrong, the Poco X3 Pro is using a better processor? Will it be less laggy and have a better battery life as well?
Miui 12.5 for note 10 pro like very laggy... Better dun upgrade..
Amoled looks clearer under sunlightIs there much of a difference in screen quality since Note 10 Pro is using amoled?
Is it games that it is lag or others? I use custom rom (Nusantara) for both phones. I don't feel any lag at all for my type of usage. Both are smooth and fast.For screen, usually can't tell the difference unless when compared. As long as 120Hz, it should looks comparable. Camera pictures / videos, guess YouTuber says RMN10P is better, then I guess so lah.
But somebody ever said before Poco X3 Pro feels more laggy as compared to RMN10P also.
So don't know liao lah.
I agree but only a little.Amoled looks clearer under sunlight
If u like to use dark modeIs it games that it is lag or others? I use custom rom (Nusantara) for both phones. I don't feel any lag at all for my type of usage. Both are smooth and fast.
I gave it a try just now. The text become more crisp and much brighter. Yes, it is nice.If u like to use dark mode
U will appreciate amoled
Wifi speed depends on ur router and fiber plan alsoJust to check, what is the Wifi speed that you guys can get over Wifi 5G?
I get about 150-210Mbps. Is this consider normal?
Sorry.. what kind of case is it again?My TPSG (bought 2 pcs) & case arrived. Watch YouTube tutorial to warm up, close all the surrounding windows to let any residue dust settle down. But somehow still screwed up 1st pcs due to stick & pull out to readjust a few times, end up used the 2nd pcs and do 1 adjustment & that's it. Didn't removed again when I spotted a tiny dust at front cam area. Just bear with it should be fine.
#ocdorperfectionist
My 3rd purchase is TPU case with 4 corners airbag & camera bump protection:Sorry.. what kind of case is it again?
