Redmi Note 10 series
PES1989
Ic.. is urs a simple transparent TPU casing (like the FOC one) but with raised edges for the camera cut-out?
He probably bought this TPU casing: I am waiting for this TPU casing & the extra TPSG w/o black borders shipping in, should receive this week based on my previous waiting time.
94d097efb43c2515e9fcb28b801bfefa
8-lane
Ic.. I'm looking for one that is exactly the same as the FOC one (just one hole for the cam cut-out instead of multiple holes) but with raised edges for the cam cut-out and no protruding "airbags" at the four corners like the one in the pic u provided has...
PES1989
Ic.. I'm looking for one that is exactly the same as the FOC one (just one hole for the cam cut-out instead of multiple holes) but with raised edges for the cam cut-out...
Ok I get what you mean, 1 big hole instead of multiple holes. Seen it on Shopee before, but didn't bookmark it. Need to search again...
8-lane
Oh I just editted my post... it should also have none of those protruding "guards" at the four corners like u can see on the one in the pic u provided.. does it?
kottty
for me i just dun care..i driving grab screen on all the time and charging always below 70%..my mi Max 3 battery still OK after 2 years usage..now this phone samei always charge my phone when it possible if battery below 70%.
Read HWZ Forum Rules!
matrix05
Where is the Build Number hidden? To tab it 7 times to access the Developer options. Wanted to use adb to do debloat.
8-lane
Ur stock case so fast spoil liao?
If u can wait can get it here, $2 nia
Will takes awhile to reach tho
https://a.aliexpress.com/_mq3JYUz
It seems like the cam cut-out on the stock case doesn't have raised edges to protect the cam lenses from scratches so that's y looking for another that does.
Thanks but I'd like one that just has one big hole for the cam cut-out.
ZhuTou!
No raised edges for cam?
My n10 non pro have leh
Just a little raised and its common to be like this
If u wan a high raised, i dun think u can find one for stock case look alike unless u go for non transparent type
