Redmi Note 7
davidwong
Hmmm and it's not a big deal for you or a problem for you?
As I depends on WhatsApp for work and communication with family non notification on time
As I also a driver GPS take a long time to work
These 2 are a no no for me for China rom
I see. :o Yes I experience it on my xiaomi devices. :o
davidwong
But bro thanks for the work around but if one depends on WhatsApp WeChat FB messenger to work and communication having all 3 app locked in the background eats up alot of ram and battery not to mention if having these 3 apps in the background plus fortnight how Ah?
The issue with messaging apps not notifying on time can be solved by locking it in the background and setting it to start automatically.
To lock app in background:
- Press Android's Menu button to list your running apps
- Press and hold the messaging app until you see 3 small icons appear (one of it being the lock icon)
- Tap on the lock icon
To set app to start automatically
- Launch settings
- Launch Installed Apps
- Under Permission, enable Autostart
This should fix the delayed notification then.
These steps are for Mi Max 3, so your steps might be different.
Posted from PCWX using MI MAX 3
meekiatah
I using Mi Max 3, battery life is not an issue. Ram also no issue, I'm on 4/64. Only storage is issue as I use both sim slots. Thought there are China sets with global ROM installed?
htngwilliam
Malaysia selling note 7 4/64gb at rm799 but no stock. For those that are keen, can just get from red white mobile at $308. Save the hassle.
Malaysia stock won’t come till month end and u need to pay rm100 deposit
Broadwalk
redwhite mobile is what rom?:o
carboy00
Hachi tech started selling RMN7. 329 for 4/64 and 369 for 4/128
Sent from Xiaomi Redmi 5 using GAGT
