Redmi Note 8
GoodBetterBest
After applying the update, when I lock in, the icons animation showing all the icons falling into the screen. Is there a way to turn this off ?
Thanks.
Woshileeroy
Hi, anyone facing WiFi intermittently disconnect and reconnecting after updating to miui 12? Redmi note 8 pro here, tried forgetting the WiFi and connect back but still same issue.
convex
No issues after update on my 8np. Overall, I'm happy with the new update.
ekardo
am I the only one that is not moving ?
I got bitten once during the last OTA that no GPS on dual screen..
i1magic
I experience a few problem :
1. Cannot cast video from phone to my Mi TV, got error. Just want to confirm any of you can cast successfully? If can, then maybe is my Mi TV issue.
2. Scrolling of video timeline playback, keep jumping to the end.
matrix05
Yes I had to flash global rom again to fix the boot loop.
The only way to make Google Pay work at that time was to install a custom recovery TWRP & use Magisk to hide the bootloader unlock status from Google Pay.
My phone got hard bricked in the end. It won't turn on or enter fastboot mode. :(
Any rescuse after hard bricked?
Kennedy
should update note 8 pro miui or not ? I usually disable the os updates for my mobiles. just feel that the updates make the os slower, battery drains faster and no significant improvement.
Rapt0r
I'm using redmi note 8 and I face the same issue as you. It started a few days ago, wifi become very slow suddenly and keep dropping connection.
carboy00
So far it's okay for me. On latest MIUI 12 on Android 10, performance is about the same as it was on MIUI 11 Android 9.
Posted from PCWX using Redmi Note 8 Pro Ocean Blue
carboy00
My dad's Note 8 used to have this issue. I restarted our SingTel router and it seemed okay now. Meanwhile it is my brother's Mi 9T that totally cannot connect WiFi, restarted the phone and router, the issue just kept coming back.
m/mink
Anyone the Whatsapps keep going into sleep/quit mode, then end up no real-time alert? I already configured all notifications, no battery optimisation, but still it will go sleep...
Rapt0r
Have tried restarting both phone and router but it doesn't help.
