Redmi Note 8
davpiyo
I brought the China version 4GB ram Note 8 GPS is slow anyone experience this?
amazingone
ya..also no text msg from TPG..
but if you read properly, step 1 is to disable VOLTE...damn weird...disable and it work..
That is to disable the carrier check for VoLTE, because if you don't disable it then your Xiaomi phone can't use TPG VoLTE automatically as Xiaomi didn't have TPG carrier profile in their software.
Plastick
any lobang for note 8 pro now?
considering between N8P or N9S...
NFC not a must. Using for games, and tanky battery life is a big plus. Dont really need camera. Never used a Mediatek Helio G90T or SD720G device before. How energy efficient are they?
Basically it's a decision on Mediatek Helio G90T vs SD 720G....
Thanks
stylechap
Thanks
Get 720g then. It's 8nm.
But Note 8 pro comes with heatpipe..lol
carboy00
Thanks
Mi Singapore Global store shopee got sale for Note 8 Pro now at 259
Mimi store got Note 9S at 249.
Since NFC not a must, I would say go for Note 9S, larger battery plus more efficient processor, will most likely be better than the Note 8 Pro. only thing is that base model for 9S is 4GB RAM, Note 8 Pro is 6GB RAM across the range.
Plastick
Since NFC not a must, I would say go for Note 9S, larger battery plus more efficient processor, will most likely be better than the Note 8 Pro. only thing is that base model for 9S is 4GB RAM, since you are in for gaming, 6GB RAM model is recommended. Note 8 Pro is 6GB RAM across the range.
thanks! note8pro was put into consideration coz for this price range it seems like a beast for games!
stylechap
Anyway the 128gb note 8 pro usual flash deal price is $279.
Comes frequently so can just wait for it than buy 64gb
samgoh87
There's no way to "wipe partition cache" for Miui 11? Using note 8 regular version.. switched it to recovery mode but it only allows me to "wipe data" instead... Which ain't what I wanna do..
And yea, I did Google but no positive results..
i1magic
Anybody can share or PM me the cheapest Redmi Note 8 Pro 6/128 local set available now?
Anything_Whatever
You have to wait for flash deal or event vouchers to get the deal, don’t think anybody can really tell you where or when .... you have to monitor this in Shopee, Qoo10, Lazada and of course Shopback.
Eg. I can tell you now (9:00pm) the price for Mi Note 9Pro is $399/- ... later 10:00pm the price could be $359/- becoz of the hourly flash deal.
i1magic
Yes. I know. I just want an indication to take reference from.
