Redmi Note 9
EveMuffins
If you want to experience 33W fast charge you will need to use their USB cable and adaptor. :o Else normal fast charge from any charger will do. :o
U mean if I use my xiaomi note 4 charger, still can fast charge but not as fast as the Note 9 charger but still charge faster than Note 4?
Broadwalk
Your adaptor and the cable has to be fast charged certified. :o If its normal charger it will act as normal charger. :o
musiKchYld
So using normal or quick charger won't do any damage to the battery right? The only difference is just charging time which isn't a big issue for me.
I thought using slow/normal charger in place of a quick one will damage the battery faster, since quick charging is one of the traits.
Thanks for all the replies!
tanchoo1
Generally speaking, the faster you charge the battery, the more stress you put on it. If you plan to change phones every year, it doesn't matter. If you plan to use it for two to three years, you may notice a degradation in performance towards the end of your phone's life.
human_shieldz
Anyone's Note 9S sometimes reboot stuck at loading screen forever until you press Power button again? Today no reason the phone shutdown then i boot up and it's stuck on load screen then goto hit the power button. Not the first time.
Nakedtoes
No problem leh. Try reflash the firmware see how..
Broadwalk
Note 9s, fast charging from 19% shows 2h55mins till 100% considered ok?
I always charge my phone from 19-20% to 100% is around 2hrs 15mins to 2hrs 30 mins. :o
I'll charge to 90% once a while so I dun "stretch" my battery. :o
I am using other brand charger with normal fast charging cable. :o
When charging, my 9pro displays "fast charging" with twin lightning icon. :o
