Redmi Note 9
VonDeVous
I have accubattery. The app does not explain, it just state so. Wanted to know the technical explanation cause I heard it often.
been following the 20-75% rule for past 1.5 years
too bad there isn't any app or software-based solution to cutoff charging at set % ... other than external mechanical/digital timer to power socket
Accubattery can set the batt % you want to stop, but will not cut off. instead, it rings to prompt user to switch off the charger.
Weekiam
Initially I bought a grey redmi note 9 pro set with mi in ear headphones from shopee but decide later to get a white one instead. Thus i request for a cancellation and went ahead to order another white one.
Who knows the next morning i notice that the supplier rejects my cancellation request and ask me to raise a request for return or refund when i got the phone.
Hence i got two orders of the same phone of different colour.
As i do not wish to go through the troublesome procedures of sending the phone back, anyone here keen to get the black redmi note 9 pro can PM me.
The Purchase will include both:
1) the redmi note 9 pro Interstellar grey 6g ram abd 128G rom
2)Mi in ear headphones basic (Black)
Selling price at SGD337
Handphone and headphone still seal and not open.
Will keep the offer open till end of this week or items sold.
Please PM me if you are interested.
thanks.
I just notice that i was not able to reply PM as i had less than 10 posts. Pai say to those bros who PM me. Can sms me @ 88053875 instead if keen. Thanks.
teoph04
Anyone using the original case? Does it have the lit that protect the camera bump?
Sent from Xiaomi REDMI NOTE 9 PRO using GAGT
Broadwalk
How’s your nillkin casing?:o does it has the depth to protect the camera bump?:o mine has a depth and with additional camera sliding cover, it helps.:o
teoph04
Mine is good, and it has the depth to protect the bump, but the cut out of the case at the charging port is a little sharp as I always place my pinky there haha
niwde1980
anyone encounter sometime fingerprint does not work and to enter password or pattern to go in phone ?
Broadwalk
I tried the charging port, think should be better gradually after some use.:o I don’t have the habit placing my pinky there though.:o
My casing texture is rubbery but firm and solid.:o so far so good.:o the only slight disappointment is the screen protector which is just 0.1% smaller else it will be perfect.:o
Broadwalk
My fingerprint sensor works well, added 3 fingers print and face recognition.:o all working 95-98%.:o occasionally may fail but repeat once will clear.:o
teoph04
Ok that's nice... I also don't like the fact that the sides black borders is cutting into the screen. Bought another one without the black borders, same brand from the same seller haha.
Broadwalk
So you removed the screen protector or you never apply on it?:o
Broadwalk
Removed the Original film n apply the glass, but don't like it all all. Haha
Understand.:o so far none of the nillkin screen protector has full size and it’s the same size as the one we got but without black borders.:o
Project_Xco
i am using original case that came with the phone. It does not protect the camera bump that well. The camera bump and the camera are actually flushed and inline.
I prefer a clear transparent case. not sure if there's any recommendation here.
GoodBetterBest
Actually, I let it charge to 100% and keep it charge. I notice that once it pass some percentage eg 80, the current slows down and by the time it's close to 100, it slows down more.
Since I sometimes don't use the phone for a few hours, I just leave it topped up until I need it. There is no charging even when plug in, just keeping it 100%.
Not sure if it's a good strategy.
zzzzzzz
Suddenly out of no where i had this "ram jet" app on home screen. I thought it was bloat and deleted it. After googling i realised its a system app.
Tried to go to system apps to enable it back but it is not amongst the list of apps in it.
Any idea to get it back?
zzzzzzz
Hearsay that constantly keeping the battery on the charger when its full is not good for battery health
GoodBetterBest
I hear this so often but I don't understand why. I think there are 2 parts to it. The heat and (I suspect) chemical change to the battery causing the damage.
Heat - already smaller current going in and is cooler. I notice that when it's in the middle portion of charging that the current is higher.
Chemical change to the battery - this I don't have info, so I assume this is the predominant reason for causing battery damage (but also not sure). I have to assume that at higher capacity (80-100%), the chemical change is higher than from 20-80% ? But I have to make this assumption to justify the reason for not charging to 100%.
I miss something ?
Also, they always quote charge cycle. So if I don't use my phone for sometimes, I just leave it charge, according to the charge cycle I actually use fewer charge cycle ?
As for the laptop, I notice in the office, there are people who permanent keep it charge and those who always go to meetings without power adapter. The latter tend to damage their batteries.
I think it will be a mystery for me for a long time to come ! ha ha...
Broadwalk
