Redmi Note 9
Broadwalk
I tried both 2.4G and 5G and encounter same issue.. and I'm on 11.03 rom.
Sent from BaL0ng L0ng using GAGT
I have no issue with my house m1 broadband, Aus router. :o
My Rom only 11.0.1.0(QJZMIXM).:o
How do you get your 9pro on different rom or updated rom? :o
ZhuTou!
For xiaomi phone
Normally wifi issue is the power saving problem
I think under miui optimization
I also forget liao
zzzzzzz
For xiaomi phone
I also forget liao
last time my xiaomi also has to undo and change many of battery optimisation settings to receive notifications for some of my apps
issit nao still same?
wifi issue how do i change it to disable save power?
zzzzzzz
any good shopee vouchers to use nao?
want to buy another redmi note 9s
Broadwalk
Always visit electronic section and claim some vouchers. :o 6/6 also have vouchers. :o Xiaomi shopee shop vouchers not as attractive as before but may change better when nearing to 6/6?:o
zzzzzzz
thankew boardwalk gor gor for the tip and trick :o
gz0707
hi , just wanna check if u guys encountered this problem on the new note 9 pro ? Phone does not received whatsapp msg whilst on 5G wifi. TIA
Broadwalk
I just switched to my home 5G wifi, it works for me. :o I can still send and received whatapp message. :o
zzzzzzz
happened twice today liao
i was on wifi still connected
but unable to browse internet or use any app which requires data
this happened when i left the phone alone for a period of time and then picked it up again
to get data working again, i had to disconnect wifi and connect again
teoph04
Does anyone encounter a pop out stating "Don't cover the earphone area, press volume up button to disable this function"? I keep having this issue when I unlock my phone
Sent from Xiaomi REDMI NOTE 9 PRO using GAGT
ronnie
Mine is 9s and have never seen the above before.
teoph04
Something like this.
Sent from HMD Global NOKIA 7 PLUS using GAGT
teoph04
Problem solved when I removed my case haha.
Devilsire
Most probably is due to the poor design of your 3rd party casing. The earphone is located on the top edge & comes with a proximity sensor, just compare it with the original casing.
btw for those of u guys whom bought tp glass (both black border / clear types), does it come with cam cutout hole or was it covered?
Broadwalk
Its one piece no cutout. :o
zzzzzzz
how come ur earphone hole is at the top?
mine is at bottom of phone
