Redmi Note 9
Broadwalk
Your screen protector seems to be large enough to cover your actual display. Mine is definitely smaller.:(
But yes, I do see a lot of dust gathering around the edges of the casing. Could possibly due to the material of the casing.
You could be right, the rubbery material could contribute static to attract the dust particulars. :o The gap between the sp edge, to phone edge then to the casing is also allowing the dust to accumulate. :o Need constant brushing and cleaning, I think I will leave it as it is. :o
Anyway the width is still shorter than the main screen display. :o So I estimate on right side next to the finger print sensor there is a slight truncation of 0.5~1mm within the limit. :o
I thought it would cover the whole screen and forming a curve around the phone edges. :o Anyway I am quite satisfied with the screen protector, responsive and good. :o
niwde1980
any encounter this before?
Sent from HUAWEI EVR-L29 using GAGT
tornedo
i thought note 9 pro 128gb will kana clear out on lazada flash sale.
but so far only 1 sold.
with coupon its 365 - 10% - 5 (shop coupon) - whatever bank rebate = <325.
tho i holding for 10x pro.
MTK YESSSSS!
How do you get the 10% discount? Can give the link? TQ
kottty
yes..is normal .start from MIUI 11 after 72hours or u restart yr phone must enter password to log in..
Sent from Xiaomi MI MAX 3 using GAGT
zzzzzzz
Do you do your finger print with casing?:o try clean the contact?:o
boardwalk tuday priced dropped to $369 plus the wireless earphone 9.90 nia
with vounchers and what not even cheaperer than the 349 i buyed last week
Broadwalk
I don’t know but it is not cheaper.:o
I don’t know what combination you looking for.:o
