Replace home broadband with mobile plan?
The_Davis
High Honorary Member
Deluxe Member
Use for 1week so far. Use about 30GB for 1 week.
Observations:
1. On mobile I switched to 360p or 480p lol
2. On tv, 480p is acceptable. 720p is ideal.
3. 4g can support up to 720p or 1080p no issues.
But multiple devices likely cannot lah.
Will continue to monitor and update once in a while.
Sambuca78
Jeremy1
I am using giga mobile plan to use to watch YouTube n online streaming.
Before that using Starhub Fibre network.
You cannot compare the connectivity between a boardband network n mobile network. Of course the Starhub Fibre network is way better. No buffering n also when you on your TV, you are already connected whereas if you used your mobile device to connect will need to take a while as when you on the TV everytime.
I had no problem with my Giga Plan with rollover data. It's more than sufficient.
The_Davis
Deluxe Member
Using 5g or 4g?
I see 4g cheaper leh
60Remajust
Life is too short not to try.
Try Liao then know if can save $ 😬
i did it before, prior to moving house and i don't wanna pay NLT lol
but still need to monitor daily usage, cannot exceed certain GB.
Its quite an experience but for me at home I rather have the freedorm to freeflow use,
play vids 4k no need to think twice
also now got simba whizcomm so cheap
888blancgmail
U can set yr daily n monthly mobile data usage in case U exceeded.
Android
Settings/ Mobile network/ Data usage/ scroll down/ Data Usage limit / set date/ daily / monthly
furryballs
have been thinking of this as well. just need 2*$10 plans and I have enough data for the month...
The_Davis
Deluxe Member
Android
Now about 12 days. I’m at 47gb used for the month.
ShinnAsuka
I use Eight (free 3mths). But Disney plus cannot play for some reason.
For Disney plus, I hotspot my main line.
2Blogic
jin boh liao
home broadband unlimited
you limited yourself
frd cum your house also wanna to connect
