Sumimasen
- Jun 6, 2018
Use hp the speed v slow deWah you use phone as modem/router ah
Ok lahUse hp the speed v slow de
I no friendjin boh liao
home broadband unlimited
you limited yourself
frd cum your house also wanna to connect
My household uses about 5gb of data daily on averageownself do evaluation how much data needed per day for you usual practice.
est. 10GB a day should be enough for youtube and online drama and surfing whole day
How much did you spend on 5g router?Running one in a mancave.
Signed up for Giga 1TB data plan. $28/month. Used as wifi.
Wifi speed seems very decent, good enough to do one thing e.g stream Netflix . Dun bother multitasking doing upload/download and streaming on TV.
App monitors the usage.
Home broadband is actually reasonable and better..
But for small commercial spaces where commercial broadband is ******* expensive, sim card can be viable option depending on usage.
I don't stream much nor play online games. 88 gb from eight free, 100gb main line 10 bucks. Cheaper than 29.90 bb.Wah you use phone as modem/router ah
Fyi, Eight had upgraded their $8 plan from 188GB to 228GB in case U need more data.Now about 12 days. I’m at 47gb used for the month.
thanks. Will switch over next 2 weekFyi, Eight had upgraded their $8 plan from 188GB to 228GB in case U need more data.
https://www.eight.com.sg/
IMHO.have been thinking of this as well. just need 2*$10 plans and I have enough data for the month...
IMHO.Update: first time encounter throttle by giga. I check the records seems like close to 10g for the day.
on my pc kanna throttled till 1.5mbps
today bought a eight mobile double eight plan ($8/mth with 228 local data)
Will update again if the plan is good.
So far the speed can match giga
so $8 > $18
Ya cos usual days I can get 10+mpbs lolIMHO.
Wah... throttle also can be tested.![]()
IMHO.Ya cos usual days I can get 10+mpbs lol
What to do buy LiaoIMHO.
For your info, I tested Prolink PRN2006L, could get 60+ Mbps download under Heya 4G.
IMHO.What to do buy Liao![]()
IMHO.there is reasons why fixed broadband still a sound choice rather than "mobile broadband"
anyway whatever float your boat.
so $8 > $18
IMHO.
"Mobile broadband" has it place when the fixed broadband goes down.![]()
But I’m now at $8 a monthIMHO, TS make his life even more difficult after converting to "mobile broadband" after all the speed throttling by MVNO and even more throttling after exceeding a certain data within a day.
fixed broadband will never had this issue.. and it cost $31 at most per month for the lowest speed plan.
