Robot Vacuum Cleaner
crandfs
Extended side crush might interfere with the main wheel. Most of them are already brushing into the wheel. If you need better corner sweeping, probably upgrade to one with extendable arm.
Wait when my order arrived I experiment
Mecisteus
Decided to buy a Dreame H13 instead.
$520+.
Hopefully this cleaning solution model can do better mopping.
hkchew03
Midea has a model that does this type of mopping too
Is there? I saw latest V15 is also base on round mop pad. Omni S1 is best at mopping hard floor, but doesn't perform as well in carpet or sweeping tho.
Mecisteus
lol cancelled my previous H13 order.
Ordered again today. Price is even lower.
Mecisteus
why don’t use robot? This one still need to use hand
Maybe in future.
The cordless W&D vacuum is cheaper and I like to see the level of cleanliness.
If not clean, most likely all the robots will fail my standard.
I am used to the traditional way of mopping.
Mecisteus
hi, dont think its for that purpose only. :ROFLMAO:
also not apple-to-apple to compare a handheld with a robot. i must say if you are not happy if a handheld steam cleaner, i dont think any robot in the market can do better than that.
Regarding the detergent, I have read on reddit.
Even dreame support cannot confirm detergent is for mopping.
Someone tore down the dreame. No tube connection from detergent tank to robot.
crandfs
1) Detergent tank to regularly dose clean water tank after X uses, and the clean water tank is used to top up the mini water tank in the robot
2) Base station prewets the mopping cloth by pumping from detergent tank and clean water tank simultaneously at base station. Mini water tank in robot contains only clean water, so mopping cloth contains progressively less and less detergent within 1 run.
I think it's probably one of these 2 methods.
elvintay07
Suspended
I made a terrible mistake by buying Ecovac. Initially ok but not spectacular. Then on and off it starts to lose wifi connection. Then on and off the speech recognition have issue. Then subsequently wifi totally cannot work. Then take back can connect for 1-2 days then spoil again. Then bring back again to listen to those clowns asking whether you know how to reset, or know how to connect to 2.4ghz band,
The first time I send in for repair (during off peak), can see 1-2 clients all streaming in. 2nd time went there, more ppl are there with their robot. This ** brand, send in 2-3 times don’t know waste how much of time and petrol.
I told myself no need to be smart Alec and just stick to Roborock or Dreame
Mecisteus
Of course lah, you go to a service center you expect to see some people.
If no people, it can also mean no buyer at all.
Number of people at service center does not imply quality.
By the way for Wifi issue, could it be your router ? Did you try to verify with another network ?
elvintay07
Suspended
First time I sent down, they say same thing as you. Then wife said they change wifi module. After that briefly connected and then spoil again. My wife is banker not engineer. But if my washing machine, smart light, lock, fan, tv, dishwasher all can connect, cannot be my wifi issue right? Elvin Tay also not engineer trained but i think simple logic I also can understand.
I see a few new models broke down lei. Like T30 omni, another one flagship x series I think. My ex roborock 4 years retire in glory. Backside itchy, now I do housework myself.
keith
roborock is a good work horse (chose roborock vs dreame arnd 2 yrs back) . now trying dreame.
both working happily .
if you like roborock, go see see dreame, its intelligence will wow you.
elvintay07
Suspended
Thanks so much. Yeah. Will buy Dreame. Which model?
