Robot Vacuum Cleaner
tlkchew
Wow, I hear your sharing also feel heart pain. You mean it will not learn that there is obstacle there after it bump the first time?
For the Proscenic, it will do the mapping and remember that there is obstacle and will not bump onto it the next time then clean the area in zip zag mode.
i am not worried about the vaccum getting scratched but my funiture and equipments. so far from what i have read is that the batt sux? @ 2000mah its sound impractical. but it seems the point about " swithch off when not in use means that when you are away for long holidays swithch off, not when finish using switch off. does the robot itself have a power down switch coz if it drains the , i presume, the li-ion batt then the battery is killed.
tlkchew
what i dont understand about this robot is that there is a feature called dark area cleaning ...other robots scared of the dark?
Nichi
Anyone here has the prosenic coco smart? how is it and does it handle multi-rooms well(4rm flat)?
looking to get one preferably with dry/wet function
beautyseek
Can anyone share Suzuka or Xiaomi robot better? Suzuka smart does not seem to have as good comments as its basic model which has more than 2000 sold. Xiaomi seems good but there does not seem to have high sales at q0010. Where do u pple get your mi robot?
breadface
I'm also curious to find out if Suzuka or Xiaomi robot vacuum is better.
windowshopper
bought the Proscenic Suzuka from Qoo10.
Works well! and like the price!
use it to auto clean the house after whole family left for work/school.
jayaian
is anyone using haier robot? saw it a few times in shopping malls recently, looks good but cant find much review...
redsuns86
Tempted to get it as well, how is it functioning? Does it get stuck when it hits your carpet?
ahbuthen
Xiaomi is a very reliable product. I have been using it more than a year since it first launch. Let it run daily on schedule and reach home with a clean floor. Good battery life, high power suction and dock well 100%. U just need to clean the brush and clear the bin once a week.
Brought from Tabbao after they launch. No regrets.
Spare parts are cheaper to get.
I am keen to either get Xiaomi or Evovacs N79.
https://www.amazon.com/ECOVACS-Robo.../B06XVXRYTM/ref=cm_cr_arp_d_bdcrb_top?ie=UTF8
Both are similar as SG do not carry them, have to import and no warranty
Anyone have any advice Thanks
ysyj48
anyone knows where to repair robot vacuum? my Haier vacuum is a bit spoiled. one of the side brushes doesnt rotate. i bought the vacuum directly from taobao thru ezbuy, so cant return to china for repair
baybiyu
Check with Autovacs. They selling irobot and doing some repair services I think.
shawniiex
So weird, proscenic/clobot has tons of sales on Qoo10, but seems like no one uses it here.
