Ryzen 2 info and Updates
Koenig168
Very impressive VRM cooling on the Gigabyte X470 Aorus Gaming 7.
ItsmeagainhK
I feel if the cooler is up to the task of keeping the CPU cool, then there is no need for after market coolers. However, it is usually not the case, and therefore, people will look for a better alternative.
Shocking! When i changed to 7700K, i reused 6400 stock cooler. CPU temp shot up to high 80 to 90 degree even without running anything, and yet to over clock. Bought a 212 cooler master the following day. Drop drastically to like 40 degree.
watzup_ken
No stock cooler will keep up if you're overclocking anywhere decently.
I think a lot of enthusiasts like to swap out coolers though. It's one of the simplest things to do even for amateurs.
The stock Wraith Prism don't look like a pushover to me even if you overclock.
watzup_ken
I feel people's expectation of stock is poor because they have been receiving lousy low cost cooling solution from Intel for a long time. That mini cooler that Intel provides is not fit for purpose if you are planning to overclock for sure. Not just is the cooler tiny and simple, but the use of lousy TIM also worsens the heat transfer.
Intel conveniently left a proper cooler out on their K series processor despite people paying significantly more for an "clock unlocked" feature.
ragnarok95
Senior Moderator
Senior Moderator
In the first place, you shouldn't even use the HS that comes with the 6400. That's why intel never include any HS with 7700K. Of cos your temperature shoot up.
Rashkae
The AMD Wraith are actually damn good.
wwenze
People doing this kind of thing is exactly why manufacturers made CPU coolers incompatible. Lucky nowadays CPU TDP are comparable and they have overheat protection, else imagine you use Pentium 3 cooler on a Pentium 4.
royfrosty
Not sure did anyone miss the promo for the wraith max when they purchase the ryzen 1 a few months back?
Those wraith max cooler is damn awesome and can be use to overclock. It is as good as the CM evo 212.
Fatfool
It's funny how the Prescott Pentium 4 processor was considered to have a high TDP when these days, every damn Processor line gets there anyway
ragnarok95
Senior Moderator
Senior Moderator
The updated one in 2700X is better too i heard. Both from coolermaster anyway.
icheb
Wait, youre saying that the Prism cooler that comes with the 2700x was designed by coolermaster?
ragnarok95
Senior Moderator
Senior Moderator
Yes.... why? Coolermaster has always been the OEM HS maker for both intel and amd.
