Ryzen 2 info and Updates
ArcticCheetah
If you want Wraith Prism coolers without the LED lights you can purchase it cheap off taobao.
Same cooler without the lights
wwenze
Yes.... why? Coolermaster has always been the OEM HS maker for both intel and amd.
Foxconn for the round ones?
I know CM makes the ones in HP and etc systems, but what about the stock AMD cute 4-sided HSF?
icheb
Anyone knows if the Asus X470-I mini itx board will be available at launch?
Fatfool
The wraith prism cooler is similar to the retail wraith max(apart from the exposed heatpipe at the bottom) which would retail anywhere between 60usd and up....so how's that for value:s12:.......my only gripe is with the awful old school clip locking thingy.
Easy on, easy off. Sure beats push pin style coolers
watzup_ken
I think the lock works well. And compared to Intel's push pin method, it is easier and less chance of poor contact.
Koenig168
I am not sure about the old version, but the one expected to be bundled with the 2700X comes with 4 heatpipes.
Yup, it's 4 heat-pipes. Also, per-RGB LED control, transparent fan blades and slightly smaller profile.
Here's a pic
Fatfool
:(:(:( okie :(
10chars
My order of preference for top tier mobo makers: MSI, Asrock, Gigabyte, Asus
I've even used Jetway and Zotac before and they appeared more reliable than Asus. VIA reference Motherboards are not too bad either if they would stop screwing up the placement of components. Very reliable though.
Thinking about this, aren't the distros going to be announcing which boards they are going to carry for Pinnacle Ridge? And those distros like Corbell to state which of the processors they are going to carry?
ArcticCheetah
What's it called without the AMD marketing?
amd 幽灵 散热器
It is just called wraith cooler I bought 1 cooling is better than Wraith Spire on my 1700 plus I hate stupid lights in my CPU
It is suppose to be those wraiths for the FX cpus looks identical to wraith max minus the lights
wwenze
Clip coolers are easy sure boh? :s13:
When you need two hands to use weight to push down on the screwdriver...
When the old single latch got upgraded to 3 latches in the later Athlon years... and the latches still can break. And the number of bare dies that got chipped.
turbin95
Anyone knows if the am4 300 motherboards sold in sls now have bios updated for ryzen 2 alr? Looking at gigabyte ab350n
Phen8210
not sure about the ryzen 2 oc potential.. my ryzen 1600x was a disappointment for oc left it at stock
Skyline34_
briefly skimmed thru a few online reviews — looks like AMD is finally closing the gap on Intel (unless i am reading things wrongly)
Hope they buck up on the gpu side of things soon...
Fatfool
AMD is already set on the CPU front for the next 2 years. I thought they could only catch up with Zen 2 but it looks like they're already there. The 8 Core Coffee Later this year will catch up though it's got like half a year before getting bulldozed by Zen 2. (Where's Ice Lake?!)
Now come on, no more Vegas.
