Ryzen 2 info and Updates
Encrypted11
The guy from an AMD affiliated coy The Stilt (Roger Tolpolla) is back
https://forums.anandtech.com/threads/ryzen-strictly-technical.2500572/page-72
Absolute IPC @ 3.8GHz
His weighted stock performance summary as with last year's analysis. He sanitised the "BIOS cheats" on both platform and notes this was on PR for Asus.
PR Notes: "ASUS Performance Enhancement" == "Default", "Precision Boost Override" & "Precision Boost Override Scalar" == "Auto" (Enabled).
Performance summary
Looks very good, but the ER sections are catered for FMA/AVX2 weakness. Zen 2 really needs to work on the 256 bit wide vector units + frequency gain should narrow the gap further.
Fatfool
~5% below the 8700K on average. But that's at 1080p though. It seems to edge out the 8700K at 4K
Koenig168
AMD is already set on the CPU front for the next 2 years. I thought they could only catch up with Zen 2 but it looks like they're already there. The 8 Core Coffee Later this year will catch up though it's got like half a year before getting bulldozed by Zen 2. (Where's Ice Lake?!)
Now come on, no more Vegas.
Pretty amazing AMD can catch up with Intel considering the difference in size between their R&D budgets.
The APUs in particular are solid value for money.
PokeMe
How about 2k gaming? Trying to think whether to get the i7 8700K or Ryzen 2 2700X.
Fatfool
At 4K gaming, the relative performance between Ryzen 7 2700x and 8700K on average is ~1%
Okay, I gave a ball park figure after reading the reviews.
Though Anandtech is reporting Ryzen 2 absolutely creams the Patched Meltdown/Spectre platforms
icheb
They are still under review, meanwhile, Anandtech's result should be considered suspect until they figure out why Ryzens cpu outperform intel's in their benchmark testing.
But if that were true, omg yeah Ryzen 2 totally creams intel post-patch.
icheb
Its about 3 percent. Honestly, I have a 1440p monitor, and I would rather sacrifice 3% performance over 8700k and get the ryzen for the extra cores, lower price AND future support for AM4 sockets till 2020. Just my two cents.
PokeMe
Alrighty, getting the Ryzen 2700X on Sat.
I read in some reviews that it should be paired with high speed rams, 3400 Mhz? I can't seem to find it in the price lists -are they even available locally?
icheb
3200mhz is good enough. you wont notice real world difference between 3000, 3200 or even 3466.
Rashkae
On AM4 you will notice the difference between 3000 and 3466. Not on Intel though
-Synchronicity-
On x370/b350, the gains are quite minimal between 3000 and 3400. Average 1-2fps difference.
On x470, seems to be the same story though first day reviews are not comprehensive enough to draw firm conclusions.
