Samsung Galaxy note 2 tips & tricks plus issues.
gibson7
i think there's a setting for s pen.
not really calibration, its for setting for right or left handers.
braduate
how do i turn off the very short "sound and vibrate" every time the S Pen is pulled out from the device? I've turned off all vibrate (Hipat etc) but still gets it.
thanks!
KoChi
Is it? I got one corner quite difficult to write using spen. But ok using fingers. Weird
king_of_diamonds
Anyone notice fps drop when playing 3D games?
I found a solution. Enable " Disable hardware overlays: under settings/Devoloper options.
kdavis
Any bro here knows how can I copy paste text from websites I visit to apps like whatsapp, messaging those kind? And then where can I find where is the clipboard in the note 2?
Sorry noob here.
TIA
zaoltryence
Sorry noob here.
TIA
Just long press on text and highlight the text and click the copy button, then open the app where you want it to be pasted. Long press text box then choose paste. I always do this when copying text on web to my notes.
king_of_diamonds
FIXED! Disable power saving mode to enjoy buttery smooth HD Gaming! Power saving mode reduce screen frame rate and CPU frequency to save battery, so turn it off when playing games
meandyou
thanks!
Setting
Spen
Pen atach detach sound
Off
transworld
Hi Guys,
When u browse your phone pics thru pc, are u able to preview them in large thumbnails? What I can see are only default pics of pc. Need to open the pic then know what is that. Thanks.
albertchng
Hi Guys,
Cannot, dont know why.
springfd
Saving S Notes
HI all, just bought the Note 2.
Having fun with Apps like S Note and S Planner. It seems that a lot both can set to sync to Samsung account. But where do the S Notes really sync to ? And how do you really back up ur S Notes.
I also log in to Samsung account on the website but i don't find any S NOtes data or back up data there.
HOpe some of you can share your experiences here.
THanks.
9N1Y9N1Y
would like to ask the same Q too, the S cloud will backup to where?
can share the website
manaeater
hi guys, wanna ask how do you all select a line of text from a huge paragraph, and then copy and paste it elsewhere e.g watsapp or SMS?
I'm fine with the selection of the text that i want, long hold on text, and drag the bars around. And then? From where can i select the COPY function?
Thanks!
carey
Thanks!
Icons are all on the top - copy, cut etc all there :s13:
dream_gal
Hi everyone...
I have been receiving sms from 1460ReutEnt, does anyone encounter?
How do I unsubscribe?
Thanks in advance.
Btw... I just found out that by holding on to the Home button, you can actually close the active applications :) I'm a new android user so sharing my "discovery" :)
kEvinErd
Is that reuters sms? Sounds like telco add ons.. Call your telco to cancel all these stupid paid services.
To backup S Note, can use Kies.. Or manually copy all the notes(file extension .Snb to the external sd card or PC?
dream_gal
Thanks for the info :)
I'll call telco to check on the smses :)
