Samsung Galaxy note 2 tips & tricks plus issues.
lenehan
Hi, need some help here. How to I remove heptic feedback for sms. I remove it from setting and it still happened whenever I type a msg. I am 4.1.2. thank you.
DoAsInfinity
have you tried this?
settings>sound>vibration intensity> haptic feedback (slide it all to the left)
narutosan
launch your keyboard in the sms window.
press the setting icon next to the spacebar (if the setting icon is not shown, it will have the T icon, just hold on to it longer and the options window will pop up and you can select the setting icon)
then under Advanced you will find Key-tap Vibration. turn it off.
samson1
Go to the keyboard settings and turn it off lah, like what narutosan said. You can also access that in Settings, Language and input, Samsung Keyboard (tap the gear icon), Advanced, Key tap vibration.
Dan008
Bloatwares
anyway to remove bloatwares? root? Will it mess up the phone? Thanks.
Kooosh
Hey guys! My Note II recently stopped receiving my emails automatically..
Email App > Settings > General Preferences >
Email notifications - Checked
Email App > Settings > Individual Email Accounts >
Sync Email - Checked
Size to retrieve emails - Headers only
... > Sync Schedule >
Peak schedule - Every 30 minutes
Off-peak schedule - Every 30 minutes
Peak days - All days selected (light blue)
Peak start time - 8:00 AM
Peak end time - 5:00 PM
While roaming - Manual
All email appears to load up and be seen in my email app only when I open up the application and click the refresh button on the top right side. Was using it fine until the last few days when I started realizing it isn't automatically appearing in my app. It seems to have stopped looking for or checking my email account for any unread new emails.
What am I doing wrong here? :/
Regional
Good day everyone!
I need help in connecting Wifi in my office. No problem at home and hotspot. Something went wrong with my office router? TIA.:s11::(
Regional
Slackersg
All gurus here, like to ask a question.
Does MEID matters in cases like unable to update and frequent SD card mounting/dismounting?
I discovered that my MEID is 00 and i have a hard time getting it to update via Kies or OTA.
Never root before and it is a retail set.
Hope to hear some advice.
TIA!
Kooosh
Anyone? Email needs to be refreshed manually..
freeman1404
HI all,
Need help and advise here,
my Note 2's TouchWiz unable to remove page.:s11: Whenever i drag the selected page to the recycle bin, it hang a while and pop up msg indicate TouchWiz closing.
Anyone encounter this before and pls advise what can i do to remove the unwanted page.
Thanks in advance.
V
victorlht88
Guest
HI all,
Thanks in advance.
haha the famous bug!
