Samsung Galaxy note 2 tips & tricks plus issues.
Mr.Taeyu
Installed Samung Kies tried to back up my existing phone settings but sync for over 2hrs witb 0% completed. Tried export also same.
I nevertheless tried to reset phone to factory setting in any case since I thought it could delete the preinstalled bloat wares but it didnt.
I then tried to use Kies to sync my outlook to N2 but also can't.
Usb setting is correct but I am unsure why I am facing such an issue
Might wanna try a few others like airdroid, double twist etc. Heard Kies not working well!
kingkangkong
Hi guys, I've been using my note2 since last friday and i've noticed that my Note2 "drops" its data connection if its not doing anything.
i.e everything on wifi is fast. but when it comes to data over cellular, it takes time to "wake up". i.e facebook or twitter or whatever app is refreshing, but u dont get the icon on the status bar to tell me that data is being downloaded. Only after a few refreshes do the icons come on and things start working.
Any of you facing the same symptoms? It was like that before OTA update and after OTA update, still exhibiting the same symptoms.
toopidpaka
Anyone can advice im facing same issue
I have flash player installed and can watch. In browser, just select Desktop View by pressing Note 2's menu button and access xinmsn.
aw1007
No luck with default browser, only can do it with Chrome.Care to share what browser u r using?
9N1Y9N1Y
I using default browser n its works
Need to ensure u install flash....
Previously I didnt set to desktop view thus it don't wk
slang
anyone knows for phone settings, is there anyway we can only view logs for calls only?
I noticed it shows everything including incoming and outgoing SMS which i am not interested. Tried view by all calls only, but it is only for that once, not permanent.
anyway to have it permanently only for view by all calls?
monkey18
go to log and click setting bottom den view by.
rae0819
Is there a way we can do to allow the stock video player to play rmvb files?
I know using another app will do the job but i like the airview of the video playback... which i dun think other apps allow... anyone knows?
TIA
otacon
Anyone have problem reading media files? No matter media on memory card or phone also no found
kambing_chua
Hi, I have also just migrate from fruit to Android and I need some advise. One thing that bugs me is, is there any settings on N2, that will show a pop up notification whenever you have an incoming whatsapp or SMS...? Or maybe it's just me that's not used to it.. Currently only the blue LED light is blinking as notification...
u can dl this app call handcent sms.... it got notification on the screen
rae0819
You can change the LED color to another color for Whatapps... just go into Whatapps->settings->notification and you can change the colors... for sms i think cannot change color...
kelvinchewtl
Bro tohchr
How do you check where the phone is made from...from some code ...teach me can.
My exchange unit from m1 works good at the moment ...
Unkletommy
Have problems downloading allshare to pc, it freezes when it tries to load java realtime, anyone can help?
