Samsung Galaxy Note 20 | Note 20 Ultra
davidwong
Agree becos when some come into the forum they are only think from tech perspective and not the pragmatic perspective
Price have gone down quite substantially.. so to some might be a good times...
plus S21 price should be higher vs... Note 20.. so it makes fully financial sense for some..
lcheowl
One ui 3.0 is here for local Exynos N20U set.
upgraded, but it seems got issue with the radio station - tested with 2 apps, after about 1 min, the radio auto disconnected. :(
Anyone facing the same issue?
at Ui2.5, my radio apps was running fine.
rainydae
I got a strange problem too after upgraded to one ui 3.0. Local exynos set.
Once everything has settled, i restarted my phone. After boot up, keep prompting S Pen disconnected. Needed to take out and put back numerous times then can get connected. Same issue after i restarted.
Posted from PCWX using SM-N986B
nuscape
I just updated to 3.0, no such issue.
Sent from Samsung SM-N986B using GAGT
Zinc-Oxide
Previously with one UI2.5 120HZ to 60hz took 5 seconds to activate. Now with 3.0, it reduce to 3sec instead. This could greatly reduce the power consumption of the battery.
aw1007
Hopefully there would be significant battery life improvement with this updates...
Zinc-Oxide
Yes I hope so, I’m frustrated why they put 5sec to activate the adaptive refresh rate and hoping they change it to 2-3 seconds. I’m glad they did in this new SW update.
nuscape
Any idea if we need to turn the device protection setting (mcafee av) ON?
