Samsung Galaxy Note 20 | Note 20 Ultra
Zinc-Oxide
Just tested my phone with 120hz for these two days and found out the battery did improved quite a bit. I'm getting around 4hour SOT and left 50% juice.
In WiFi mode 120hz
Ui2.5: 14-16% per hour
UI 3.0: 10-12% per hour
And finally Now I'm confident to use 120hz and I still remember how buggy the adaptive refresh rate was when I first bought it.
KeYoKe
In WiFi mode 120hz
How about on 4g/5g?
nuscape
If you are on UI 3.0 already, can anyone share 'care report' screen if it is showing the same info about dropping phone. Or is this a warning report that my phone was dropped before? See my screenshot below.
Sent from Samsung SM-N986B using GAGT
rharish_21
My S20+ with one ui 3 doesn't show those fall related information.. It just shows about battery charging best when it's 10 to 40 percent..
lcheowl
suspected is a random message.
mine show this
davidwong
See if you can find any promo think the stock is already low Liao so the best promo and pricing already gone hopeful the cny promo you can get good pricing.
Icic... Okok, seem like not much diff though. Shall consider to hoot local n20u... Exynos...
Zinc-Oxide
Ya now price is much stable so is worth getting it new for around1200. I'm still happy that i bought this new set at $1300 4 months ago.
The adaptive refresh rate is getting more stable and now it can go down to 48Fps when previously it can't for whatever reason.
The auto brightness for ui3.0 is too bright, dont really like it.
rabbit1
it can always go to 48FPS.. except in low light environment.
Zinc-Oxide
Icic I didn't noticed that, I was trying out using the UFO frame test at the website and when I hit volume button, it will drop to 48fps when previously it can't. Thanks for clarifying that
whencatsruletheworld
Hi guys how's the battery life with the new update?
New update pretty smooth. Doesn't heat up as much - slightly cooler this time.
Battery management is better. Able to hit 5-6 hours SOT with 4G/5G and up to 7hr SOT with WIFI. No power saving mode, and on 120hz adaptive. Overall very satisfied with the update.
Zinc-Oxide
Yes this is what I'm getting too. Very happy with the new update as for now
