Samsung Note 10/10+ Accessories Thread
trenzterra
I ran a brief wattage test using the following equipment that I have on hand with my Note 10+.
Phone turned off and battery at 10%.
Readings taken after cable plugged into phone for 30 secs (As the voltage and current readings fluctuate on the USB meter during the first 15-20 seconds after plugging in)
USB Meter
- Ruideng TC64
Charger
- Aukey PA-Y12
USB C to C Cables
- Anker PowerLine II (USB 3.1 Gen 2, 100W)
  • 9.20V * 2.74A = 25.21W
- Anker PowerLine II (USB 2.0, 60W)
- Mazer (USB 3.1 Gen 1, 60W)
  • 9.50V * 2.86A = 27.17W
- Baseus (USB 2.0, 60W)
  • 9.53V * 2.74A = 26.11W
Contacted Aukey with regards to PPS on PA-Y12 and below was their respond.
- Maybe the PPS compatibility issue could be why the charger is not hitting 45W on the the Note 10+?
- My PA-Y12 and cables could reach close to 60W (PDO) charging my laptop.
I have two PA-Y12s. One could hit only 15w while the other charges at 25w. Very strange.
teoph04
I'm sorry if this was discussed before, does anyone know where can I get the whitestone around suntec or bugis area?
Sent from Samsung SM-N975F using GAGT
Glariel
Red white mobile for Bugis area
For Suntec not that I know of
elmariachi
MiniSq at Square 2 if you can. They did a great job pasting my Whitestone. Very happy with it as my last Zeelot peeled out by my daughter. Glue used on the Whitestone is so much better and the oleo-phobic is like the phone without screen protector. Extremely good! No issues with FP so far and to me it works faster than the Zeelot even though that recognized my FPO without issues. Keyword here is faster unlocking.
teoph04
Ok thanks for the info
Tony.Manero
From the review it seems a bit rubbery and not smooth like the original pre-installed. Did you try?
I installed the amfilm tempered glass instead. Bought both
Tony.Manero
Just buy that amfilm lah. 2 pieces still cost less than 1 piece of white stone :s13:
808ster
Bugis area you can go p2o. But I think they do not apply for you.
