Samsung Note 10/10+ Accessories Thread
delrosa81
Abit thicker than spigen.
Is it very thick? Possible to share pics?
aerolord
May I check what cable can I get to utilise the fast charging? Got two different cables from Challenger, but somewhat slower than the OEM cable that is provided in the box
camoguysg
Haha, get it done at the shop then. After few days of usage, glass still working n no peeling effect on the sides.
Sent from Samsung SM-N975F using GAGT
How about the fingerprint sensor? Does it work all the time? I am thinking of changing to wsd cause my current one fails like 50% of the time.
Adam80
Best is to stick with the in box charger and cable the difference between super fast charging is very little
teoph04
If you got the position of the fingerprint sensor correctly, it's almost 100%, just hold it longer than usual can liao.
samgoh87
Hi guys, is it really worth the $$$ to invest in WSD TGSP? Anyone using UAG case with it as well?? =)
camoguysg
Thanks!! I finally got it installed and it is finally working a lot better!! Thanks again!! :)
camoguysg
For me the wsd is definitely good...only pity it has a cutout for the camera but finger print sensor works better imo.
For case i am using the defense shield with no issue, although it takes a bit of patience to put it on...its pretty tight.
radzkal
any recommendations of shops to get back film protector from? saw casefactorie has them for $8 but wana know if got other options.
