Samsung Note 10/10+ Accessories Thread
xiaoheng
i jus install WSD on my phone myself... sensitivity wise same as the default scr pro samsung give... good enough
earthtk
Bought this to try.. previously someone recommended in s8/s9 that this supplier make quality and trustworthy glass.. will feedback when it arrives. Seems like they got the tools to make fingerprint sensor work by thinning the glue at the sensor.
https://c.tb.cn/h.eLyFn8T?sm=9685c3
Sent from Samsung SM-N970F using GAGT
kenzon
Any recommend shop to install Whitestone dom for note 10 plus. How is the sensitive for finger print scan.
Currently naked without screen protector.. Can accept 90% sensitive
samsungXP
Where u got it applied ? Maybe try your shop
Sent from Nokia 3310 using GAGT
clementi pasar behind mrt
Sent from Galaxy Note 10+ using GAGT
samsungXP
anyone set custom equaliser for the sound ?
bawawaw
Currently using this. No issue on fp. Easy to install too. Seems not affected by the current issue on gel protectors (other users can login).
hippo1n2
Over time it will left scratches mark and Spen fractionated
Sent from Nokia 3310 using GAGT using GAGT
jeezycheezy
Is anyone using okonz screen protector together with ringke fusion X? Will it lift up the screen protector???
lorettatay
Where to buy?
Sent from Samsung Galaxy Note 10+ GLOW GLOW GLOW using GAGT
