Samsung Note 10/10+ Accessories Thread
camoguysg
any recommendations of shops to get back film protector from? saw casefactorie has them for $8 but wana know if got other options.
Eh the phone already comes with a film protector behind, so u dont have to remove it if you dont wish to. (I didnt). No need to spend so much for back protector unless you gonna use the phone without a case.
hippo1n2
I got this matt from slickwrap
Sent from Nokia 3310 using GAGT
samgoh87
But hor.. anyone having issues with the fingerprint sensor when using WSD? I've re-register my fingerprints and turned on touch sensitivity, but it'll still usually fail during first 1 to 2 tries and needa press on hard...
Any advice ?
camoguysg
Any advice ?
Mine still fails sometimes but a lot lesser than the previous brand i installed. My advice will be to turn on the facial recognition as a backup. Its really a lot a lot faster than using the fingerprint sensor. Im currently relying on facial recognition for most of the time, and then use finger print and pin for Samsung pay instead.
Also it is good to register a few prints of the same thumb/finger.
Tony.Manero
Any advice ?
They key is to apply just light tomoderate strength. If you press too hard, wonder if the screen will crack. There's a one to one half second delay but the finger print does work. And make sure record 2 for each finger
Tony.Manero
What I mean is if you press very hard to register the finger print, the finger print will only be recognized if you press that hard again, which is not what you want.
Audiology93
Collected my OTG at Vivo SES today. Just go all the way to the back counter and tell them you're redeeming the OTG.
Sent from Samsung SM-N970F using GAGT
whezzy
Hi all, any travel adapter with USB C that can deliver the same speed of charging as the stock charger?
idjekyll
Which shop has a good selection of cases I can check out? I've shortlisted the Otterbox Symmetry, Rhinoshield Solidsuit and maybe the Spigen Liquid Air as a spare. I may drop by to mobyshop at far east. Anywhere else?
doki81
casefactories has lot of note10+ cases..but all BNIB..don't think they have display unit.
dc7176
is the samsung clear view cover good? no review??
thinking of getting it coz of the notification.
Sent from Samsung SM-G955F using GAGT
Tony.Manero
If the cover is curved, it's going to be very awkward when you fold it to the back
radzkal
if anyone is looking for kickstand cases, spigen ultra hybrid s is only good for viewing media. it's not sturdy enough and imbalanced for use with s-pen. maybe can try esr kickstand case which is a third of spigen's price.
