Samsung Note 10/10+ Accessories Thread
Ye_Rongtian
Whitestone glass got any issue with fingerprint?
=( my current 淘宝taobao one cannot detect.
With the exception of the 1st generation of Whitestone of S10, there have been no further issue. Any issue with the fingerprint now is due to the skill of the person pasting it.
buaians
My zeelot no issue. Pasted at casefactorie. If your fingerprint got issue is due to the skill of the paster. If got bubble issue multiple times, is due to the irregular glass curve of your phone. U need a stronger uv glue from China to fix the problem or stick with plastic screen protector.
Where ar? And how much?
Sent from Samsung SM-N975F using GAGT
trenzterra
I paste at casefactorie too. Last time my s10 also paste with them three times, different people. Also same issues after a while. Lol
lifeinmono
Using zeelot now.. pasted yesterday. Went to Gadgets Flair at Berlinton square.
Need to delete existing finger prints and reconfigure. No issue.
samsungXP
how much
Sent from Galaxy Note 10+ using GAGT
earthtk
Go taobao buy that one.... $45 can buy 4 pieces and have spare change. Drop and break still can change.
Sent from Samsung SM-N970F using GAGT
xiaoheng
any bought Dbrand Grip case now got offer but not sure if it will lift WSD Glass or not
Adam80
Do you guys charge your phones in all Aircon environment? Noticed my phone charges really slowly unless I point a fan at it...
Which charger you use?
Inbox charger or others?
If you using inbox charger it will display Blue circle and fast charging(it's normal)
trenzterra
Both stock charger and aukey PPS charger. Checked using Accubattery. Seems like when phone temp is about 39 degrees charging will slow down.
If charge in Aircon or got wind blowing at my phone to lower the temps, it charges really quickly. 2 to 3 percent per minute zoom from 30 to 80 in 20mins.
keenklee
With or without cover?
idjekyll
Anyone can recommend a good soft PU screen protector? Been using the stock SP but slowly showing scratch marks already.
St00ky
Feel like changing my UV tempered glass. Current one got bubbles at the top edge and a line at the center of the screen. Any good shop to recommend? Is it hard to remove the UV tempered glass?
