Samsung Note 10/10+ Accessories Thread
yhscsl
Went to replace my screen protector today at samsung westgate
As in the original screen protector which it comes in?
Pathfinder
the curve edge will stick down swee swee? they will provide install or can opt for self install?
Sent from Samsung Note 10 + using GAGT
The curved sides are swee swee. They claim they have a machine to install, so I let them do it.
Sent from Samsung SM-N975F using GAGT
Bo0geyman
Anyone using DEX with a portable monitor?can recommend any decent portalbe monitor? thanks!
MasK
Hi guys,
I noticed the box on the Note10 Whitestone SP states that it works with the FP scanner, but the S10 box does not.
Does this mean that Whitestone guarantees that it will work on the Note10?
Anyone using Whitestone on the Note10 can share your results?
Thanks!
Glariel
Hi guys,
Thanks!
Depends on how it is pasted
elmariachi
Hi guys,
Thanks!
I have both S10+ and Note 10+ pasted. What Glariel said is correct, depends who paste. If you want Whitestone, get it installed at MiniSQ at Square 2. I have had both my phones done there and I have no issues with FP sensor. Yes it takes slightly longer to register but that is the case with all TGs. I am very happy with Whitestone so far. I've had Zeelot before and the glue used isn't strong. You will have lifting at the edges over time. Whitestone till today still perfect.
MasK
Thanks for the MiniSQ recommendation. Will check them out.
I have used Whitestone on my Note9 (passed on to wife now) and it's still awesome after 1.5yrs. Was just concerned with the FP reader.
Also, after Andrioid10, I feel the FP reader is faster too (S10).
elmariachi
Yes absolutely! Even my Note 10+ with Android 10 seems faster even with my Whitestone on. Make sure you set increase touch sensitivity in settings as that is what Whitestone recommends as well. Very happy with it untill today with great oleophobic on the Whitestone as well! :D
Snoweagle
That free one is good, but will probably last you 6mths or so... or depending on your tolerance for scratches :o
Been using mine since 26 August and now only got a small hairline scratch on the right side at center area, other than that it’s scratch-free.
