Samsung Note 10/10+ Accessories Thread
MasK
If you don't need fancy features like touch, ambient sounds, etc, check out SoundPeats. No frills. Good in fundamentals - sound and connectivity, at a fraction of the cost.
shanz80
i would like to replace the SP for my Note 10+.
currently using the one that comes with the set.
any recommendations?
TIA!
:D
Glariel
TIA!
:D
whitestone dome glass.
its tempered glass though. my mum using it for her Note10+ and she drop few times screen still intact.
shanz80
expensive and useless.
got it for my previous phone.. it still cracks anyway.
:D :s8:
Glariel
Still depends on how you use lor
All the tempered glass out there I still feel Whitestone better.
I used for my Note 8/9 no issue
:D :s8:
Tony.Manero
If you remove the sp, whitestone will come off in one piece while chiong ones will break.
shanz80
if paste le whitestone, then u wont wan to remove it liao mah.
haha.. the only time to remove it, is when its cui.. so one piece anot doesnt matter lah. LOL
Tony.Manero
The chiong ones break into pieces when you try to peel it off. Making it harder to remove. You'll want to remove it if you dropped it and it cracked or chipped.
