Samsung Note 10/10+ Accessories Thread
shanz80
The chiong ones break into pieces when you try to peel it off. Making it harder to remove. You'll want to remove it if you dropped it and it cracked or chipped.
oh, u meant chiong de. LOL.
if i wan buy whitestone, i will go for original.
but then its overrated.
any other recommendations?
Glariel
not really, u can buy others but sensitivity wise will not be as good as those glue tempered glass
earthtk
I used Whitestone before ever since the first release of their protectors. Decided to try something else and I feel this 'pirated' version is much value for money, while achieving it's function of a protector does and provide without compromising the phone function.
Well. Each to their own.
Sent from Samsung SM-N970F using GAGT
shanz80
Thanks for ur view. :D
earthtk
I checked this link via EzBuy and it is up to $45. Is that true? If that's the case, isn't it better to get the Whitestone instead?
Cheers
Hmm dunno about ezbuy but I shipped directly from tb... Around $45 for 4 pieces before shipping charges.
rainbow99
hi can anyone advise is there any shop that sells note 10+ privacy screen that's compatible with the finger print sensor?
AlvinPwn
Anyone here use Note10+ Whitestone Dome?
Wanting to buy the alignment frame from ya if you willing to let go
Tony.Manero
Don*********t think there is one exists in the market
Anti-Peep-Privacy-Screen-Protector-For-Samsung-Galaxy-Note-10-Pro-8-9-s10-S8-S9.jpg_640x640q70.jpg_.webp
s10 note 10 all have
