Samsung Note 10/10+ Accessories Thread
MasK
Today I replaced my WSD protector with Okonz, it was a good experience. The fingerprint sensitivity is way better than WSD and the feel is better. Fitment is good as well. Saved $ for a protector on par with WSD.
Bro, its been 3mths. How's the FP sensor working so far?
I've had a terrible experience with WSD and planning to give this a go after going naked for a few months..
Cheers.
kitoshizc
Cheers.
FP sensor is working well still! However, after I drop the phone, the glue stains can be seen a bit at the corner where the impact was.
MasK
Cool!
I just got Okonz last week for my Note10+ and yes it works. I love how thin is stealth it feels.
And right after my wife's Note9 died and I passed my phone to her. I'll go back to him for my Note20U some day. Tampines too far :s13:
tanjimmy
Cool!
Where you get your Okonz done?
Sent from Samsung SM-N975F using GAGT
radzkal
Which 3rd party charger do u guys recommend for super fast charging? Or is there a reputable seller for samsung 25w charger?
kitoshizc
besides whitestone, okonz and zeelot, any other loca glue uv adhesive SP you guys used before with gd fingerprint sensitivity?
earthtk
I recommended quite a few times here. Can get from taobao with 1/4 of whitestone dome price. The oleophobic coating is as good as whitestone or better. and very lasting. But of course you will need to follow their instruction properly for a good fit.
I recommend buying a few as backup although you won't change frequently.
If I get any ultrasonic samsung phone, this will be the first go-to. Work well on s20 plus too.
https://m.tb.cn/h.44TxHcn?sm=7685ec
Sent from Samsung SM-N970F using GAGT
trenzterra
I using baseus gan fast
Which version you using? I bought the 120w during 11.11. but it only super fast charge for 1min, after that it disconnect and reconnect as normal fast charging
trenzterra
Cool!
Last time I tried okonz with S10+ but had issues with fingerprint and the glue at the edge was quite unsightly.
After 1 year of using Zeelot I got fed up and changed to a PET screen protector from Taobao. Not as smooth if you use the pen often, but clarity wise feels the same as loca TG. The most amazing thing is that the fp works 100% of the time now. Light touch, heavy press, all no issue. Last time I sometimes had to even lick my finger just to get it detected (now abit unhygienic due to covid)
kitoshizc
will take note! thanks
yawbus
The link doesn't work anymore. Could you please repost the link,or better still send the product/shop name ? Many thanks in advance !
samsungXP
Sent from Galaxy Note 10+ using GAGT
spell
Is this link the same shop ?
https://item.taobao.com/item.htm?id=598349985387&price=153-218&sourceType=item&sourceType=item&suid=53b45565-610a-4c5e-b759-deb0dfaf979d&ut_sk=1.WucErIJDUu0DAAR9%2FIQyApSP_21646297_1571316226146.Copy.1&un=41e0f9a6418f32446c63b333dcb4f84f&share_crt_v=1&spm=a2159r.13376460.0.0&sp_tk=4oK0Um1uMFlLS0pySEnigrQ=&cpp=1&shareurl=true&short_name=h.eLyFn8T&sm=9685c3&app=chrome
