Samsung Note 10/10+ Accessories Thread
大蛇丸 Orochimaru
Hi, 大蛇丸 Orochimaru,
Your white stone is working properly with fingerprint? I got mine installed at mobile stop, authorised applicator.
Yes. I ownself applied. It's working even better than with the original plastic film. I bought mine from qoo10 whitestone dome store.
How I apply (using official whitestone dome UV light):
1. UV light on top 60 secs, UV light on bottom 60 secs
(don't worry, it won't dry up, glue will still be wet). 15 secs is too short. Even if your glue dry up, the glue residue can easily scratch off using fingernails
2. Use the micro fibre cloth to wipe off excess glue on edge gently. Don't use alcohol swab, even a little bit of alcohol seep in the edge of screen, the edge will get ruined with air bubble.
3. Press your thumb hard on fingerprint reader position on screen, hold for 1,2 mins.
Change grip, change position, repeat this step until u are satisfied.
4. Final cure. Let it cure gao gao, use UV on it like 5 mins on all areas to make sure it's 100% cured without taking any chance that it's not fully cured.
5. Turn on increase touch sensitivity
6. Enjoy your new screen protector
7. If u are perfectionist, can use fingernail to scratch off any remaining tiny glue residue until u are satisfied.
Hit the like button if I helped any of u here.
SwaKu
HI folks,
My wife lost the bundled AKG USB-C earphones with her Note 10+ and need a replacement. I've saw a few sellers on Shopee and some buyers commented that the so call Original AKG earphones are noisy, same issue with the AKG replacement I bought from a shop earlier.
Anyone can recommend a USB-C earphone that will work well with the Note 10+ for calls? The mic is important as she needs it for calls. She has wireless earphones but complain that the dropouts and poorer voice quality are annoying.
If not, can also recommend me a decent USB-C to 3.5mm adaptor so that she can use her old samsung earphones for calls.
Many thanks for your advice and recommendations in advance. Have a good day.
大蛇丸 Orochimaru
HI folks,
buy an adapter will do
samsungXP
Sent from Galaxy Note 10+ using GAGT
rubber33
Anyone keen on ringke fusion case? 15 dollars including postage. Sold my note 10 plus already.
kitoshizc
Today I replaced my WSD protector with Okonz, it was a good experience. The fingerprint sensitivity is way better than WSD and the feel is better. Fitment is good as well. Saved $ for a protector on par with WSD.
tanjimmy
Where u get your screen protector replaced?
Sent from Samsung SM-N975F using GAGT
Haman
Hi, is the Note 10 plus original screen protector from Samsung shop still available? Anyone last tried? Thanks.
Cyno505
I called Samsung customer service, the original screen protector that comes with the phone is not available for sale. Some Experience stores sell 3rd party ones. As to which store, will need to call the store to check.
Someone here said he done it at Westgate. Not sure still have.
Haman
Thanks, we went to Westgate today and he say don have this screen protector..
damienloh
Got a Note 10+ recently and a tempered glass (unknown brand) at Lot One ($39.90). The guy helped to put the tempered glass on in less than 10min. Here's my experience.
Scenario 1.
Registered a "clean" finger print before putting the tempered glass. After putting the tempered glass, the finger print sensor failed 99% of the time.
Scenario 2.
I deleted the "clean" finger print. With the tempered glass still on, I registered a new "dirty" finger print. "Dirty" here means it capture the finger print with the distortion from the tempered glass as well. It took many tries and about 10 minute to complete. The time has not been wasted because now the finger sensor work well finally.
Scenario 2a.
Additional optimization:
i. Double tab to wake up the home screen first, then use the finger print sensor. It works 95% of the time.
ii. Disable battery optimization on com.samsung.android.biometrics.app.settings
aw1007
Wow Snapdragon version really not bad.
Still got 49% after 5 plus hrs screen on time...
Sent from Samsung SM-N9750 using GAGT
Red8310
Hi all,
Do you know what is the tactic to register your fingerprint when using magnetic case w/o hole?
