Samsung Note Edge
meandyou
Really not much ppl getting this phone.. My friend working @ starhub attended to 1 and only 1 customer who bought the edge during launch day
xphobic
Good then I then there will be plenty when I get back in Sg over the weekend.
Sent from GAGT Android App
Densocool
I believe Singtel sold more edge over other telcos, perhaps some promo drive between samsung and ST.
derrickgoh
Anyone knows how to change the apps on the edge screen? Googled but can't find anything.
derrickgoh
which part edge panel apps you what to change?
Ok I am using Firefox so I would like to replace the default browser icon with Firefox icon. There is one folder in the edge panel too and I'd like to replace some of the apps there too. Can this be done?
IceShelterX
I just noticed my edge have no complete silver lining new top of the stylus. anyone have the same?
Azuredrak
Got it...in slp mode...swipe the side bar left and right...:s13:
too new to edge...:s13:
Doesn't seem to quite work for me leh? By left and right, did you mean the longer way or the shorter way? I tried swiping it in boh directions, but the time didn't show up. On the other hand..when I wipe my side screen with a clothe, the time randomly shows up.
Azuredrak
Post a picture? The top part is supposed to be silver in colour on the sides, and black in the middle. Silver surrounding black.
Like this.
Azuredrak
All app shortcuts on the side screen can be replaced. Go to Settings-->Device-->Edge Screen-->Manage Panls--> *You now see the strips of curved screen templates, yes? There's a PENCIL icon at the bottom, press that.
Now you are brought to a screen showing all your app on the left side,and the currently existing apps on the curved screen on the right side. Drag the apps from curved screen to the left side to remove them. Drag the app you want onto the right (curved screen).
To create a folder, drag one of the desired app onto the curved scren. From the curved screen, tap and hold the app, then move it to the top section which says "Create Folder". You can then drag and drop additional apps into the folder.
lzhihao
I juz placed the phone flat.. and swipe left and right.. hmm..found out right and left will also triggers it.. abt 2cm distance.. the longer way if u mean..
lzhihao
Haha.. the best function of this phone is.. when i'm playing fifa.. calls comes in will not interupt my gaming.. haha edge side bar will display answer/reject slider..
derrickgoh
Oh its the pencil! Lol! Thanks
KOPS1974
Think on the edge, you can also tap on the star.
