Samsung Note Edge
derrickgoh
yes confirmed... the same... :s13:
look at bottom silver lining of the picture... there is a white square... near stylus area.... at both left and right...
Exhaust for hot air? :s13: I notice Note Edge tends to heat up quite quickly compared to Note 3.
IceShelterX
:s13: im using the silicon bumper... so exhaust will not work... no wonder my phone so hot now...
I think if on processing with all utility on (GPS and LTE) all samsung phone heat up.
So far i play COC and okay leh. not feeling the heat. but when i play golf and use it to pair with LG G watch for course and distance calculation... can feel the heat after 3 holes burning out from my pocket...
renfred89
No leh. Never download. Only open and view from within email.
You mean for your phone you see the default apps for PDF, doc, etc?
This is all that I see:
i see.. hmm then i dunno how already.. so far i have been able to replicate that message asking me to open once or always using a particular app after clearing the defaults..
seller4
Try clear default for Email since you open the PDF in email. If still does not work, go to Application Manage and clear the cache and data of the Email app and reset the apps from scratch.
derrickgoh
Brilliant! Clearing default for Email worked! Thanks! It started to ask me again what default app for viewing PDF, jpg, doc, etc.
And many thanks to renfred89 to for trying to help!
seller4
Glad it solved your problem. Cheers! :)
derrickgoh
Me want to know too. Seems that it came out from the top side only. Only yahoo email appears on the edge panel.
Ok I've been paying attention and I notice when I receive msg via SMS or Whatsapp, they appear in the Edge screen. Not sure about FB though. Too many things to pay attention too. :s13:
0400392G
was trying my luck to see if any otc covers for edge, went to namh at tampines interchange.. this was the cover.. pretty decent I would say and thin
Lance321
I find the edge is quite laggy..anyone feel the same?
Try turning off all air gesture features and location features if you don't use them. Turning off sync when you don't require it. See if that helps. I have played with the demo phone at the store and it seems laggy until I turn those features off. Same goes with the note 4 as well.
Deavenger
I had those on for note 4 but no problem
Fellowes
Just realize that Note edge battery won't last as long and the option to turn off LED indicator for low battery is being remove, it now only have a tick and untick in setting unlike S5. The RAM usage is surprisingly high.
ritzboi13
To customise led indicator, download from play store.
Genome123
Love the innovative design of this classic note line but alot of places claim it isn't selling well due to the high tagged pricing.
