[SIC] Engine oil promo
Tyrian
Just wondering why nobody recommends the manufacturer's own oil?
Honda, Toyota, Lexus and Mercedes all got their own oil, iirc
Fatfool
Viscosity thicken or thinned according to temperature, if the manufacturer recommend 5w40, they mean it to be at max 100'c. And with every 10'c increase, like to 110'c then you should go 5w50 for it to act like 5w40 at 100'c.
If you see 120'c then you should choose w60 and so on, something like that.
OOoo noted thanks!
trex101
mine usually hovers around 80+ degree after warm up and normal driving with occasionally boost
so can use w30 eh? i'm on w40 now
if i drag gears then will go up to 90 or 100+ of course but seldom la :s13:
usually
Definitely, at 80'c+ your w40 will be acting like w60, you definitely can go w30 if you want to gain more power and FC.
trex101
Because Honda, Toyota, Lexus and Mercedes doesn't actually produce any oil, they just ask those oil manufacturer like Mobil or Shell relabel one of their products for them for sale.
Mobil or Shell themselves do carry a wide range of products range with different prices and performance so from the price quote, you more or less know which tier formula you are paying for.
botoguy
noted bro...
so if assuming i bought from my engine oil from somewhere else for eg, Giant then bring to your shop, will the charge still be 12 + 6 = 18 ? :)
If you want the best fuel economy for your car, just choose the thinnest oil that your owner manual recommended. Usually it is 0w20 or 5w20, so go for it, no point save $20? on getting 5w40 and yet pay $5 extra everytime you pump petrol by losing mileage. From w40 to w20, usually you gain around 30-60km per tank.
Labour cost for oil change at mxtradings are $12. So for example
Pennzoil Ultra Platinum 5w20 $16 x 4quart = $64
oil filter = $6
So total = $64 + $6 + $12 = $82
trex101
noted bro...
Sorry the price quote are for our customers only, not for outside oil.
seowbin
wah, mai tu liao, next oil change
this is another reason why i don't change to later gen of vw car is because their oil temp hovers around 90+ to 100+
while my stoneage car is 80+ range :s13:
maybe because cause of the built in water heat exchanger used to cool the engine oil
HKS_Hippo
Suspended
Trying Lexus 5w-40 in my Corolla now. Just used for 300km
Previously Mobil 1 Gold 0w-40
limkopilimteh
usually i can only feel the "new engine oil" for a short while. Engine seems more alive for a few days. after that, it goes back to feeling normal.
This was tried with several brands from Amazon. I guess engine oil really not much different ba, unless u driving some sports car.
trex101
Feeling can be misleading and not all engine oil are created equally.
” Passenger car motor oil is the lifeblood of your engine. In addition to lubricating moving parts to help reduce wear and tear and the buildup of heat in your engine, motor oils contain performance additives that help to reduce oxidation, neutralize acids, prevent rust, corrosion, and foam, condition seals, save fuel, and keep your engine clean. But all engine oils are far from created equal. In fact, some motor oils on the shelves can cause harm to your engine and premature failure. Know what motor oil goes into your car”.
Quote: PETROLEUM QUALITY INSTITUTE OF AMERICA
SAMPLE SUMMARY /PASSENGER CAR MOTOR OIL
In fact, if you look at the testing below, those unknown/relabel products have the most problem and some will actually do damage to your car engine.
http://www.pqiamerica.com/samplesummaryPCMOrev4test.htm
botoguy
noted.
can recommend me the cheapest 5w40 4 quart of engine oil pricing please? beside the standard labour fee 20 and filter 6 :)
trex101
noted.
Schaeffer fully syn 5w40 at $13.50/quart, $54 + $12 + $6(most jap car model). Schaeffer 5w40 is actually very good just do a Google on it and there is lots of review in BITOG forum.
warr
shell 5w40 4L at $39 not good enough? go to giant.
