SIMBA Fibre Broadband
slash
Previously the reports of SIMBA 2.5Gbps plan users seem to be pretty bad. The new reports of 10Gbps user seem to be bettter. But then people may not want to change.
Yes, user fivefootway's test results look promising. Only thing left to see are their uptime and stability.
I'll have to wait till my current contract almost up before subscribing. Maybe same just utilise 2.5Gbps until all those 10Gbe equipment prices comes down ...🕘🕐🕑🕒🕓🕔🕕🕖🕗🕠🕞🕝🕜🕙🕚🕛
stillgottheblues
To those that have signed up and technician did not have to physically enter your home, what is your method of application? If I were to sign up using your method is there a way to confirm at the point of sign up whether or not a technician has to physically attend? Thank you
The technician need to enter the house and check the fiber activated but you can only plug in the router and use after you have received another email from SIMBA informing you the Internet has been activated.
Evolver
Simba 10Gbps is finally available at my home area. Thinking whether to upgrade to this (currently on M1 500Mbps for $30 per mth) at same price and to pair it with the free TP-link BE230 router from upgrading my parents' house M1 broadband. While the speed will be limited by the 2.5Gpbs router, its basically at zero incremental cost to me while getting a 5x speed boost
sglandscape
Do you need a public ipv4 address? If no then it's a choice worth considering.
joesph
that's by wire only. and that tp-link router no 6GHz band
Evolver
Not at all. I'm just an average simple user.
Netflix, Disney+ streaming, mobile & tablet phones + Tapo home cam (which I saw in earlier threads that no issue for use with Simba).
To me, I'm indifferent. Given my simple requirements - I doubt I can feel any speed difference in real life between M1 500Mbps vs. Simba 2.5 or 10Gpbs. I just want my monthly subscription to be lower - that's all. Simba 2.5Gpbs used to cost $21.80 and that was a good motivation for me to switch. Now the price between M1 and Simba are similar at $30. I'm wondering whether I want to go through the hassle to switch when there's hardly any material cost savings.
Apex
It's best if you can stay with the new ISP for 4 years (2 renewal cycles) since there are NLB activation fees whenever you switch between ISPs. Do take note of this.
Cursor
Guys, I have my SIMBA 10Gbps setup yesterday and currently facing some slow loading issue. Just to find out do you encounter any issue from your SIMBA fibre BB when loading movie from this link "https://www.olevod.com/player/vod/1-57941-1.html"?
If yes, may I know how do you resolve this issue? I am currently using google DNS and do not have any VPN installed.
eddy0505
No issues loading on my end. 10gbps Simba plan handicapped by 1gbps wan port. All default settings, using the same routers from my m1 500 Mbps days while waiting for the new ones to arrive
chiu2000
Loads immediately on Simba Mobile🙃
Sethide
For those who have switched from M1 to Simba, do you have to cancel your M1 subscription yourself? If yes, when do you that?
Thank you.
stillgottheblues
No issue for me. Better than M1 1gb in fact breeches the website I go for streaming videos don't stuck at loading as often as when using M1.
stillgottheblues
SIMBA 10gb plan got no charges other than the 1st month $29.95.
joesph
i in china using vpn ok
