SIMBA Fibre Broadband
just signed up for simba and they did the activation
i am only getting the following speed
please help :(
my simba ont is connected to this
https://www.tp-link.com/my/home-networking/wifi-router/archer-ax73/
and the router is connected to the following powerlines
https://www.tp-link.com/us/home-networking/powerline/tl-pa8010p-kit/ to connect to my pc via ethernet
Kind of expected for Power Line adapter.
My D-Link AV2000 power line adapters can only achieve 100Mbps to 250 Mbps at different rooms.
Multiple limitations with your setup.
1) TP-Link Archer AX73 is only up to 1Gbps.
2) Power line adapters will go up to 400Mbps at best in typical Singapore household. And I have never seen anything above 350Mbps using Power Line adapters in this forum.
Nefalrin
please help :(
Do a direct speed test from inside your router by logging in the tp link router website.
This is mine from Asus router login..
I believe there is no such function with TP-Link Archer AX73 (or similar TP-Link routers). Only the high end ones may have such function.
BTW, even for Asus, low end ones with 32bit CPU (BCM675x, RT-AX56U/58U/82U, ZenWiFi XD6/XT8/ET8) will probably not be able to exceed 1Gbps.
Those with BCM4908 CPU (RT-AX86U, GT-AX11000) will be good with 1Gbps and almost there for 2.5Gbps.
Those with BCM4912 CPU (RT-AX86U Pro, GT-AX11000 Pro, GT-AX6000, ZenWiFi XT12 Pro) will be good with 2.5 Gbps.
Those with BCM4916 CPU (ROG GT-BE98, RT-BE88U, ZenWiFi BQ16) will be good probably below or just nice at 5Gbps (to be confirmed) but not good for 10Gbps plan (around 8.2Gbps download)
Nefalrin
Then he have to plug in a laptop directly to the router or ONT to do speedtest
So Simba is 3years contract under their t&c
Where do you get such incorrect info?
Minimum contract period is 360 days (slightly less than one year).
https://simba.sg/broadband
SIMBA Broadband 10Gbps Critical Information Summary
https://simba.sg/static/media/CISBroadband10.6cf91326.pdf
SIMBA Broadband 2.5Gbps Critical Information Summary
https://simba.sg/static/media/CISBroadband.bb9bbd66.pdf
Both has the following info.
1.1. SIMBA is providing you (the “Customer”) with access to unlimited home broadband Internet
access over the SIMBA Fibre Broadband network for residential use (“Services”).
1.2. The minimum contract period for our Services is 360 days.
jrwong84
So many complaints look like a sinking ship plan don't understand why you all sign up with them :ROFLMAO: don't tell me is cheap unless your 2 years plan can save above $500 vs other company.
ShaiDoesMac
For the memes, why not? 🤣
But for real, I wanted to try 2.5Gbps without some link aggregation bs that the other ISPs are doing (splitting out 2.5 or 3Gbps into 3x 1Gb ports).
Also the pricing for 2.5Gbps / 10Gbps internet without having to pay for any NLT & ONT installation activation fees is definitely an enticing offer.
Ya, the company and customer interaction experience is lacking- but honestly them changing name from TPG to SIMBA to fit into our Singaporean-ness should at least expect to meet the minimum expectations mah…..
This should be a key takeaway for them to improve their CRM and CS relations, at least can improve their branding to offer as a true competitor. But as it stands right now, SIMBA genuinely looks like some new Gen Z shizz company that probably hasn’t known how to deal with quick support on customer requests yet.
While I am indeed miffed and picky / whiny about them missing the first appt, I’m willing to put up with this bs because I see the potential value, and probably once I get my activated connection I’ll be pacified until it goes down during an outage.
Mach3.2
huh, don't expect much support from simba leh. it's really no frills and I'm not sure it's worth going for since the cost savings isn't huge, and it comes with drawbacks like lack of support and CGNAT.
yukita
My friend RT-AX88 also unable to hit 1gb on internal speed test. I thought that is very strange.
The CPU is good (BCM49408) but RT-AX88U has only 1G WAN port. So probably at most 940Mbps. There are some other overheads as well so it will be a bit lower.
yukita
He can only get 500-600, while his pc can get 900 over :s22:
Just set up simba today. No one from NLT came. Just plugged in ONT and everything worked.
Moved over from m1 1 gbps because of cost. Speed has increased 9x based on speed test. From 100mbps to 900mbps. I didn’t change any equipment except plugging the simba ONT directly into the mesh rather than a router.
How did you know that you are still not connected to M1's network? Have you terminated it? Are you using the same fibre port?
chottohen
It’s a different fiber port and also, I only have one mesh network and only one ont can be connected to it. It’s either simba or m1.
That is on the lower side, when I was using Singtel 1Gbps, I got about 800Mbps+ download from my Asus RT-AX86U's embedded OOkla SpeedTest app. Upload is at full speed 940Mbps+.
Now I am using RT-AX86U 2.5G WAN (Singtel 5Gbps plan, as a sub-router) and the download speed is 1600Mbps+, again upload speed is more or less at full speed at 2.3Gbps+.
ShaiDoesMac
Update #4
It's alive now boys.
NLT didn't ring my door today, but noticed the ONT router turned green at 10am this morning.
Now to wait for my NanoPi R5C to saturate that 2.5Gbps bandwidth.
Tested my connection with my Gigabit motherboard and I am not disappointed.
